Author Topic: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers  (Read 670354 times)
Offline Towlerar
Re: Siglent SSA3000X and SSA3000X-Plus Spectrum Analyzers
« Reply #1225 on: August 12, 2020, 03:13:05 pm »
Please excuse my ignorance, as I'm a newbie at this sort of thing. If one needed to restore their equipment from a NAND dump, how would that occur? Is that done via JTAG interface?
Offline tv84
  • Country: pt
« Reply #1226 on: August 12, 2020, 03:35:40 pm »
Opening the unit and, via UART, using the bootloader functionalities. No need for JTAG. If the equipment is somewhat working you could also try some NAND replacements via .ADS files.
Offline Billy33
« Reply #1227 on: August 14, 2020, 02:53:59 pm »
Another instrument upgraded successfully, thanks a lot to all i got support from, and especially tv84!
Method was according post #1223 step by step plus some inputs afterwards.
Offline echo99
« Reply #1228 on: August 15, 2020, 09:18:05 am »
Found out one can use FTP client to transfer screenshots and measument data from the instrument. Is there also a way to enable write access to the internal storage to create folders and rename files?
Offline Elasia
« Reply #1229 on: August 15, 2020, 11:41:44 am »
Grant yourself telnet and go to town
Offline TK
« Reply #1230 on: August 16, 2020, 08:38:04 pm »
Does the cross flashing to SVA1032X work on the SSA3015X plus?
« Reply #1231 on: August 16, 2020, 09:30:08 pm »
I guess you mean SVA1015X.
SVA1032X has a different LF VNA spec that suggests the HW is different. Check the datasheets.
Offline TK
« Reply #1232 on: August 16, 2020, 09:36:12 pm »
No, I mean SSA3015X plus.  It was announced recently.
https://siglentna.com/news-article/siglent-ssa3000x-r-plus-spectrum-analyzer-family-welcomes-new-models-new-functions/
« Last Edit: August 16, 2020, 09:38:23 pm by TK »
« Reply #1233 on: August 16, 2020, 09:45:56 pm »
Oh wow....yes probably to your original question.
Would be nice if Siglent let their distributors know about new models.  :palm:
Edit
Check the datasheet TK. Maybe no to your question:
https://siglentna.com/wp-content/uploads/dlm_uploads/2020/02/SSA3000X-Plus_DataSheet_DS0703P_E03A.pdf
« Last Edit: August 16, 2020, 09:58:05 pm by tautech »
Offline tv84
  • Country: pt
« Reply #1234 on: August 17, 2020, 01:51:16 pm »
Looking at the datasheet and knowing about the SVA1015X and SVA1032X differences, maybe this new SSA3015X Plus can only be crossflashed to SVA1015X.
The following users thanked this post: rf-loop, TK
Offline Elasia
« Reply #1235 on: August 17, 2020, 10:34:28 pm »
This would plug the missing SSA from that 1.5GHz slot, i was surprised they didnt roll it out with the SVA 15
But yeah it couldnt cross flash with the others, its a different hardware set.. only the SVA1015X would be its match
Offline JAROLD
Re: Siglent SSA3000X Spectrum Analyzers
« Reply #1236 on: August 19, 2020, 03:24:49 pm »
Good morning all . Thank you for this Forum which is really great. I bought an SSA3021X in May 2020 with the TG option. I want to toggle my options permanently like EMI and Monitor FM. Unfortunately I am not an expert in Linux and I am a little lost in the correct method to apply to open all the options keeping the serial number and my option valid from the TG. Currently, I still have 34 hours of validity because I have not yet installed it in my workshop. If anyone on this forum can help me or point me to the best fit page for my model, I would be very happy.
My Siglent SYSTEM INFO :
SW1 1.2.9.3a
SW2 20180708-1
SW3 000000E1
HW  0F.03.00
Offline TK
« Reply #1237 on: August 21, 2020, 03:29:55 am »
Crossflashing to SVA1032X final step
For all those that want to get an official "SVA1032X" designation after having crossflashed their SSA3000X+, the only thing that you need to do is replace the firmdata0/NSP_trends_config_info.xml file with the attached one.
Reboot and voilá.
PS: This is a stock NSP_trends_config_info.xml taken from an "original" SVA1032X.
Hi tv84, thanks for the awesome work on this SSA/SVA crossflash!
* However, I suspect your attachment is wrong, it seems to be an .sh file (with the dumpnand script) instead of the NSP_trends_config_info.xml
* Also, I have crossflashed my device (to the latest 2.2.1.2.8), but still have XXXXXXXXXXXXXX as serial number / SN.
What's the way to do this right, while retaining all licenses as "Permanent" ?
Screenshot of my current system info is attached.
I can see RT40 activated... does it work on this crossflashed SVA1032X?
Offline tv84
  • Country: pt
« Reply #1238 on: August 21, 2020, 08:34:08 am »
That is for SSAX-R.
Offline iulisan
« Reply #1239 on: August 25, 2020, 02:26:59 am »
HELP PLEASE :((((( I JUST BRIKED MY SSA3021X-PLUS :(((( I follow the 1223 post and now my siglent does not boot up the TG and MODE are light but that is all.PLEASE HELP.
Offline Precut
  • Country: tw
« Reply #1240 on: August 25, 2020, 05:01:34 am »
You need to get access to the internal UART interface to see console message.
Offline Elasia
« Reply #1241 on: August 25, 2020, 10:47:02 am »
You will need to open up the back of the unit and plug into the uart vias as detailed a bit back in this thread, once you can paste what your boot messages are, one of us can walk you through it more than likely, worst case is usually a partition nand reflash from the uboot preboot prompt
Offline iulisan
« Reply #1242 on: August 26, 2020, 10:58:47 am »
Now : 13:41 , 26.08.2020 I WILL do that ! Wish me luck .Thank you all for the support !
Offline olc
« Reply #1243 on: August 26, 2020, 12:17:34 pm »
Hi @iulisan,
Do you know what step bricked it?
Offline tv84
  • Country: pt
« Reply #1244 on: August 26, 2020, 01:11:22 pm »
For sure: not following the instructions to the letter.
Offline iulisan
« Reply #1245 on: August 26, 2020, 02:25:12 pm »
Offline iulisan
« Reply #1246 on: August 26, 2020, 02:26:13 pm »
I will kill myself :(
Offline tv84
  • Country: pt
« Reply #1247 on: August 26, 2020, 02:33:20 pm »
Take a deep breath and wait for @Elasia.
Are you sure you have your serial port well connected and configured? Verify all once again.
Offline iulisan
« Reply #1248 on: August 26, 2020, 02:48:16 pm »
I've tryied with 2 computers , 2 terminals all native serials.Puty and hercules show the the same ==it :( do not know :(
Offline tv84
  • Country: pt
« Reply #1249 on: August 26, 2020, 02:50:11 pm »
Sure, but what about the the SSA pins? Are they correct?
The following users thanked this post: iulisan
