So I've finally got around to starting a Tindie Store - I'm just waiting for the mods to approve my product listings. Currently I have 6 products with 2 more designs about to be Built and tested this week.
https://www.tindie.com/stores/CyberneticSys/
I recently bought a Tandy 1000 HX and I'm planning to buy a couple items from your store but I was wondering if you might be able to help me out with a couple questions I have regarding the converters before I do.
I've been looking into the possibility of using an internal iomega ZIP drive on the Tandy 1000 HX using a Lo-tech IDE adaptor. From my understanding, this should work, and the issue may be power supply. From what I read on the product page of your floppy-to-gotek adapter, it would also be possible to use a standard PC floppy drive with it, but from what I have read on forums, this wouldn't be a good idea on the Tandy 1000 HX as it may damage the power supply...?
The internal ZIP-drive has a standard molex connector on the back so using your floppy-to-gotek adapter, and then a molex to 4-pin floppy power connector, that is my theoretical idea to power the ZIP-drive.
Now my question is, is this a good idea, or does this setup have the potential to damage the Tandy's power supply? Or, have I overlooked other potential issues?
