Author Topic: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project  (Read 103636 times)
0 Members and 15 Guests are viewing this topic.
Offline bitseeker
Re: Tandy 1000 ex/hx PLUS Expansion to 8-Bit ISA Riser card project
« Reply #226 on: July 18, 2018, 06:25:32 am »
Yeah, that might be just what you need. :-+
Offline djosTopic starter
« Reply #227 on: July 18, 2018, 08:20:41 am »
I just ordered some parts to try out.  :-+
« Reply #228 on: August 27, 2018, 04:54:32 am »
So I've finally got around to starting a Tindie Store - I'm just waiting for the mods to approve my product listings. Currently I have 6 products with 2 more designs about to be Built and tested this week.  8)
https://www.tindie.com/stores/CyberneticSys/
Offline bitseeker
« Reply #229 on: August 27, 2018, 06:41:58 am »
Cool! You'll probably want to put your stuff on eBay as well, if you don't have them there already.
« Reply #230 on: August 27, 2018, 07:03:09 am »
I've sold via ebay before, but it's not worth it for low volume stuff like mine - you have to Jack up your prices to cover the ~20% in fees you end up paying.  :-[
Offline bitseeker
« Reply #231 on: August 27, 2018, 07:27:15 am »
That's OK. It's free marketing. Some won't care about that difference and just buy it. Other shoppers will Google the product name to see if it's available other places at a better price and find your Tindie store.
Offline raffie
« Reply #232 on: October 28, 2018, 01:41:37 pm »
I recently bought a Tandy 1000 HX and I'm planning to buy a couple items from your store but I was wondering if you might be able to help me out with a couple questions I have regarding the converters before I do.
I've been looking into the possibility of using an internal iomega ZIP drive on the Tandy 1000 HX using a Lo-tech IDE adaptor. From my understanding, this should work, and the issue may be power supply. From what I read on the product page of your floppy-to-gotek adapter, it would also be possible to use a standard PC floppy drive with it, but from what I have read on forums, this wouldn't be a good idea on the Tandy 1000 HX as it may damage the power supply...?
The internal ZIP-drive has a standard molex connector on the back so using your floppy-to-gotek adapter, and then a molex to 4-pin floppy power connector, that is my theoretical idea to power the ZIP-drive.
Now my question is, is this a good idea, or does this setup have the potential to damage the Tandy's power supply? Or, have I overlooked other potential issues?
« Reply #233 on: October 28, 2018, 08:23:41 pm »
Howdy, TBH I don't think I'd be concerned about powering an IDE zip drive from the floppy 5v power, the zip drive uses a Maximum Continuous 800 mA and a Peak current draw of 1.65 amps. A typical floppy drive peak draw is 500mA with continuous draw of 450mA.
Many folk ran 3.5" hard drives internally back in the day and I reckon those old beasts would require way more current than a zip drive. Admittedly they'd have used 12v, but there's only 2 amp supply there.
The HX power supply can sustain 3.0 amp current supply on the 5v side.
« Reply #234 on: November 04, 2018, 04:42:12 am »
Hi Guy's, I'm having a pre-Xmas 10% off Sale for the 1st 10 orders from my Tandy 1000 adapter range this month!
Use the code: 6F445D33 at Checkout.
Apparently the above code isnt working for some folk, so here's another one just in-case: 67FC73DA
