Indeed. I might have to move the big book on a desk behind. Windows come in handy while working at nights. There's a good view of the sky when it's a clear night for some extra inspiration.
@gore: I think you will be annoyed when you have your bench loaded with a project and then want to open one of those small component trays on a lower tier and find what you have in front interferes. Maybe put the component storage box higher, mounted on the wall or on shelves.
@chickenHeadKnob
Good point. Building a bench platform seems like a good idea for elevating the trays. Plenty of room above. I left one outlet way up in case there's a need to add a wall mounted display.
Yes, shelving looks like it would be useful to maximise desk space.
Also regarding the scope, I think I'd either operate it upright on the floor (sounds bad but it's much more ergonomic than you might think) or get a lower profile unit and put it on a shelf, it's taking up an awful lot of desk area.
But yes, a massive transformation.
I'd also try and find some space to put a netbook when a computer is needed, which could be a lot more often than you expect.
Ain't this the truth... Datasheets and schematics... Personally i have monitor (flat lcd) and small mouse and small keyboard on work desk. Easy to put aside if i need more space, often i dont... Computer itself is located in floor, next to desk...
Flat screen monitor plus an under-desk sliding keyboard and mouse, assuming it can be fitted to your desk. That's been my setup for a number of years now.
To me, a computer is an essential piece of equipment at the bench. Right now I'm using a small tablet for viewing schematics and datasheets, but it's clumsy business, so a proper laptop or a stationary computer is required. I've seen many cases of laptops being held by an arm type holder in this thread. That's some beautiful stuff.
Worth getting one for sure. Placing a keyboard/mouse under the desk is a simple task. The scope's massive. Perhaps I should bring in a small profile digital scope on this bench, but on the other hand, you can use the scope itself as a desk, which is what I'm doing. Placing it on the floor would make it inconvenient for making quick adjustments on the scope.
To me, a computer is an essential piece of equipment at the bench. Right now I'm using a small tablet for viewing schematics and datasheets, but it's clumsy business, so a proper laptop or a stationary computer is required. I've seen many cases of laptops being held by an arm type holder in this thread. That's some beautiful stuff. Worth getting one for sure. Placing a keyboard/mouse under the desk is a simple task. The scope's massive. Perhaps I should bring in a small profile digital scope on this bench, but on the other hand, you can use the scope itself as a desk, which is what I'm doing. Placing it on the floor would make it inconvenient for making quick adjustments on the scope.
You could mount a tablet to the wall pretty easily (with velcro etc) and plug in a keyboard/mouse for it to do most quick google searches etc. It would be easy to take down when needed too, and could have datasheets up constantly in a non-intrusive way. Could also mimic a local PC screen pretty easily (RDP etc) if you needed to check something
I got one of these that holds two monitors off the desktop. They are GREAT!
Those are gerat! And pretty cheap on Amazon
http://www.ebay.com/itm/Single-LCD-Monitor-Desk-Mount-Stand-Fully-Adjustable-Tilt-for-1-Screen-upto-27-/171297260958?pt=LH_DefaultDomain_0&hash=item27e21cc59e
I have one similar on my workbench. I use a KVM switch for my company test computer and my personal laptop docking station. Under desk keyboard/mouse tray completes it. Now I need a freestanding dual monitor stand for my ham radio desk. I need something that is more adjustable than my DIY solution.
my messy bench, actually it became a place to stack up stuff. In the process of sorting/organizing.
You must be working on a 7075,I wanted one.
My 7065 Vref has drifted out of range or( something else is wrong) the closest I can get it to 10V is 100ppm out
shame really, I learned about 6.5 digit meters from it, and acquired more gear to fix it
wallet says
Correct(), I will have another go at it over the summer. When I got it no links were soldered(not good).
I did manage to fix the 120pa of bias current though. Cleaning didn't help much, but accidently breaking a wire/ resoldering it did.
All my analogue scopes and meters are now in the attic. Just replaced the ESD matting, moved the workbench into the corner of the room and here is the result...
Tannoy Coaxial's - don't see those everyday. I used to have a pair of SL-1700MK's for all that vinyl too.
Where do you keep all your parts? Looks like you have a panelized PCB that would need a bunch of parts.
Indeed, I have plenty parts stocked up... That's a vocoder PCB on the bench... The resistors (TH & SMD) are to the right of the vinyl, then on the other side of the room is where the mess is (I'm still in the pocess of tidying)... There's also a couple of cabinets full of components & tools under the workbench.
What do you use the big Tannoy speaker for? Is it a continuity checker for the hard of hearing?
I have them mic'd up to the whistle on my kettle...
my new setup, just installed new Led lights below the shelf.
Still missing equipment, but it's getting there
Are those Ikea "stick" lamps any good? Also what voltage to they run on?
I was in Ikea yesterday and couldn't decide if I should get a couple as work lamps.
If you are referring to the Jansjö, then it's quite popular on the forum - do a search to see some opinions.
There are USB and mains powered versions - the mains models use a 4V 3W adapter.
Busy with something else, so as I had the camera out and was busy.......
Even had a visitor to the grapefruit tree outside, looking for some crunchy lunch for himself.
