Author Topic: Siglent SDS1104X-E and SDS1204X-E Mixed Signal Oscilloscopes  (Read 623303 times)
Offline Gabri74
« Reply #750 on: May 30, 2018, 04:19:21 pm »
I've asked the status of the issue (figured my direct contacts should work quicker than the distributor + tech support chain) and learned the following:
Siglent have identified the problem. The new version isn't compatible with all the previous ones. There will be a new package release soon that will fix that.
Thanks a lot Performa01, that was very kind of you   :-+
I'll wait for the update then. Thanks again.
Offline Giuss
« Reply #751 on: June 04, 2018, 03:56:59 pm »
I haven't updated yet, so I'll wait the next release
Offline Performa01
  • Country: at
« Reply #752 on: June 04, 2018, 04:36:58 pm »
Well, I would guess if you update to the 20R1 firmware prior to attempting the update to 25R1 then everything should work fine. It's only some older firmware versions where there's a compatibility issue. At least I had absolutely no troubles updating from 7.6.1.20R1 to 7.6.1.25R1 and I think the same is true for all the others who made this update step. The only other issues have been with the OS update when using incompatible flash drives.
Offline Performa01
  • Country: at
« Reply #753 on: June 05, 2018, 09:06:29 am »
Everyone who had compatibility issues with the latest firmware update, please find the corrected package for V7.6.1.25R2 here:
https://www.siglentamerica.com/download/6422/
EDIT: Siglent seems to have done their homework. There's a lot more fixes than just the broken remote control:
  • Fixed the bug: Once the acquisition is stopped, the scope often can't find search events in other channels.
  • Fixed the bug: In certain situations, the scope freezes when the Auto Setup button is pressed.
  • Fixed the bug: The Pass/Fail mask is not correct at edge of screen left and right.
  • Attenuation and invert indicator were added into the channel tab.
  • Any arbitrary probe factor from 1e-6 to 1e6 can be set by universal knob.
  • Got rid of suffix 'A' that stands for 'Acknowledge' from I2C decode.
  • Fixed the bug: The dedicated window for long I2C data sometime lose data at right edge.
  • Fixed the bug: The decoder sometimes does not show any info.
  • Fixed the bug: After updating to the last firmware and OS version, the remote panel/control interface can no longer be connected.
« Last Edit: June 05, 2018, 09:17:55 am by Performa01 »
The following users thanked this post: tautech, tubularnut, zabox909
Offline firstcolle
« Reply #754 on: June 05, 2018, 09:13:27 am »
I also see various bug fixes form R1!!
« Reply #755 on: June 05, 2018, 09:46:52 am »
'I' for Invert.
Updated screenshot.
OK Siglent, good stuff.  :-+
Now please add some of this to SDS1202X-E, er no, actually all SDS****X models.
« Last Edit: June 05, 2018, 11:40:52 am by tautech »
The following users thanked this post: Bob Sava
Offline Performa01
  • Country: at
« Reply #756 on: June 05, 2018, 10:03:11 am »
Custom probe, now adjustable to 6 decimal places and settable to even more than that. Not that more than 3 digits would make much sense, but better too many than too few ;)
SDS1104X-E_Probe_Custom_Fine
Offline iMo
  • Country: pm
« Reply #757 on: June 05, 2018, 11:15:22 am »
In a few months of such an improvement's speed people will finally get their "ideal oscope", it seems :)
You are right, those 0.123456789x is something people would not appreciate too much, better to stay with 3 digits and an exponent, say +12..-12 (tera..pico). Best in "Engineering" notation/format..
« Last Edit: June 05, 2018, 11:33:40 am by imo »
Offline Performa01
  • Country: at
« Reply #758 on: June 05, 2018, 11:35:55 am »
We certainly get the engineering notation if the factor calls for that:
SDS1104X-E_Probe_Custom_Fine_Eng
EDIT: Just noticed - have you ever seen such a noise-free trace at 3µV/div?  ;)
« Last Edit: June 05, 2018, 11:38:06 am by Performa01 »
Offline iMo
  • Country: pm
« Reply #759 on: June 05, 2018, 11:43:49 am »
Examples:
1.23 x
123 x
1.23E-3 x
12.3E12 x
-235 x
-2.35E6 x
-23.5E-9 x
-235E-12 x
These coefficients must not be related to the "probe attenuation or gain" but generally to a "measurement". For example you may watch an waveform at the -2.5V/100pA output of your DIY pico-ampermeter, with stock 10x probe. So you will dial "-2.50E-9 x" in.
« Last Edit: June 05, 2018, 12:22:46 pm by imo »
Offline kerouanton
  • Just curious about science, radio etc.
    • Sometimes I play with radio
« Reply #760 on: June 05, 2018, 01:36:54 pm »
Can't wait having mine... it's in transit, should have it in a couple of days, with the LA option  :)
And funny enough, my old Hameg 205-3 just "died" 2 days ago, leaving me with a crap DS-203 as my "main" scope (better than nothing). Already repaired it a couple of times but this time it's the CRT and I don't have a high voltage probe. So far so best.
Siglent does seem to do a good job at fixing their software, that's good sign.
Offline Gabri74
« Reply #761 on: June 05, 2018, 04:18:00 pm »
Just installed the latest update and I can confirm it solves the issues with the remote panel not being accessible.
Now everything works as expected!
I have to say that I'm really pleased with Siglent response and attitude  :-+
Thanks to Performa01 and simone.pignatti for your help  ^-^
The following users thanked this post: Performa01
« Reply #762 on: June 06, 2018, 12:54:31 am »
Using the 4ch 4 different probes setup from a few posts back I shot a very basic vid showing remote display responsiveness for possible any big screen or projector presentation use/needs.
SDS1104X-E webserver via WiFi to laptop which in turn is connected to a VGA 18" monitor. Took only a minute or two to setup.
Done from my phone so nothing flash, just a quick demo.
~50s
https://youtu.be/W30AqcDQL18
Offline 17_29bis
« Reply #763 on: June 06, 2018, 05:34:21 am »
The latest 25R2 firmware update fixed the problem with I2C decoder and a strange suffixes. Now it can display long strings (it looks a bit bizarre though due to the strange padding but none of data is truncated now).
It is still  not possible to display the long data correctly at the string located at the bottom of the screen, you will never see the end of the decoded data of the packet longer than 30 bytes simply because Siglent does not allow to scroll the bottom string to the left - the first decoded byte must be always visible (but why?) and therefore most they can show is 30 hexadecimal bytes.  Not  a big deal for me. May be one day they will fix it simply to be not just  "really good" but "almost perfect"  8)
« Last Edit: June 06, 2018, 05:39:13 am by 17_29bis »
Offline Giuss
« Reply #764 on: June 06, 2018, 05:49:00 pm »
I've completed the update without any problem, everything works and the webserver is very nice now
Thank you for your support
Offline kerouanton
« Reply #765 on: June 06, 2018, 09:56:32 pm »
It seems that Siglent fixed that I2C display issue quite quickly. That's enthusiatic.
Offline rstofer
« Reply #766 on: June 07, 2018, 04:09:38 am »
~50s
Thanks for that!  I just happen to have some 27" monitors on my PCs, a perfect size for old people.
That scope is looking better and better.  One of these days I'll have to buy the SDS1204X-E.
« Reply #767 on: June 07, 2018, 05:36:24 am »
~50s
Thank you.
Yes there's nothing like a small video to show the real responsiveness.
That was just really to demonstrate how they can easily be used for presentation purposes, something that you'd ordinarily need to spend a lot more $ to achieve with a DSO.
You've probably seen screenshots webserver remote UI and that's quite excellent too and full control can be done with a mouse.......maybe another simple video coming........but with a small digital camera instead of shaky damn phone.
When I communicated with rf-loop shortly before these were released, the phrase 'hardcore' he used alerted me to how good these really could be, even though I'd beta tested one and had some idea this was the case myself.
His words based on his vast experience are proving correct.
They're certainly very well featured for the money and very few won't be surprised of how capable they are. For the 'first DSO' buyer these are truly a scope you can grow into by adding further functionality options when you need them.
It's certainly the best value for money we've seen from Siglent as yet.
Yeah I know.......sales blurb and all that, but look hard at other offerings and those that can really see will see what owners do too.
Also thanks to those that have given the valuable feedback for Siglent to improve these DSO's to what they have become.  :clap:  :)
« Reply #768 on: June 08, 2018, 08:27:56 pm »
Siglent USA have done a short video on the webserver.
Some explanation on the improvements, usage and further improvements to come.
https://www.siglentamerica.com/video/x-e-4-channel-web-browser-update-this-thing-is-fast/
Offline Pannenkoek_met_een_lampje
« Reply #769 on: June 09, 2018, 03:25:53 pm »
Can anyone please tell:
me if this is a known bug?
https://www.eevblog.com/forum/testgear/strange-behaviour-of-siglent-sds1104x-e/new/#new
Sorry for the separate thread, do I need to ask things like that in this thread?
thank you all
Offline tv84
  • Country: pt
« Reply #770 on: June 09, 2018, 07:50:15 pm »
Looking into the SDS1000X-E fw, one can see that the 250Mhz and 300Mhz is a possibility (in sw terms, at least).
So that would mean a SDS1254X-E or SDS1304X-E only would lack a proper "logo".   :popcorn:
And that would match what I've read in this thread that Siglent has 300Mhz probes in the inventory.
If anyone wants to test these bandwidths...
Offline toli
  • Country: il
« Reply #771 on: June 09, 2018, 08:06:37 pm »
considering the fact its will go down to 500MSPS when both channels on the same AFE are active, 200MHz is about the maximum. You could go higher when only a single channel is active (at 1GSPS), but then there's a need to add this LPF back to avoid aliasing with more channel active. Would be interesting to see if its implemented this way   ;D
My DIY blog (mostly electronics/stereo related):
http://tolisdiy.com/
Offline radiolistener
  • Country: ua
« Reply #772 on: June 09, 2018, 10:02:24 pm »
Here is screenshot of 100 MHz square wave with 1 ns rise time. I got it with my 100 MHz SDS1102X:
The Rise time is measured as 1.70 ns, it corresponds to the bandwidth = 0.35 / 1.7 ns = 205.8 MHz   :popcorn:
And here is even more - 290 MHz square wave with 1 ns rise time:
The Rise time is measured as 1.02 ns. The bandwidth = 0.35 / 1.02 = 343.1 MHz...  :bullshit:
Offline 17_29bis
« Reply #773 on: June 10, 2018, 02:55:19 am »
Very interesting. As far as I know the recent versions of firmware don't provide 50 om Impedance option for SDS1XXX X-E series (1102/1202 - 1104/1204), this menu item has been removed long time ago. Are you running some sort of a very old firmware?
« Reply #774 on: June 10, 2018, 08:34:00 am »
BW is dictated by the -3dB point, nothing else !
Significant signal attenuation is evident once you go past the rated frequency
Some examples:
https://www.eevblog.com/forum/testgear/siglent-sds1204x-e-released-for-domestic-markets-in-china/msg1553074/#msg1553074
The SDS1102X that radiolistener has is a different series to X-E and does have 50 ohm inputs.
This model series, 8" display but only 2 channels:
https://www.siglentamerica.com/digital-oscilloscopes/sds1000xx-series-super-phosphor-oscilloscopes/
