ahope:
Have you tried this one?
https://siglentna.com/service-and-support/firmware-software/waveform-generators/#sdg2000x-series
SDGX Labview Driver 1.0.1 (Saved for 2014 version) (Release Date 05.14.19 ) https://siglentna.com/download/8860/
I plan to buy the Siglent SDG2042X, the last firmware version is 2.01.01.35R3B1, so I'd like to know which is the best way to hack it, downgrade->hack->upgrade or using this way:
https://www.eevblog.com/forum/testgear/siglent-sdg2042x-hack-door-closed/msg2409867/#msg2409867
whitout dowgrade and upgrade?
Release notes
Optimized debounce of the front panel buttons.
Release notes
Only one change, but a much-appreciated one! The way the function buttons below the screen also serve to toggle between modes (e.g. amplitude/offset vs. low/high level), it is really annoying when they bounce and register extra keypresses. Despite my attempts with various techniques -- gentle pushing, resolute pushing, pecking, ... -- some of the function buttons on my unit have driven me nuts!
Will try that update tonight. Thank you for the heads-up, tautech!
Last year I wanted to buy a Siglent signal generator. I remember they offered 30~50 % discount! I couldn’t believed it. But I couldn’t buy it!
This year I saved my money to buy a Siglent signal generator but today I checked Amazon but there is no special discount! I have forgotten the date Siglent had offered the discount.
Do you know When Siglent is gonna offer Special discount?
So I just received my SDG2042x and I went to download the latest firmware and EasyWave from Siglent's website. Windows Defender SmartScreen is blocking these files, declaring it might malicious content.
So I just received my SDG2042x and I went to download the latest firmware and EasyWave from Siglent's website. Windows Defender SmartScreen is blocking these files, declaring it might malicious content.No such issues here on a W10 PC running Chrome.
All 3 sites look fine.
US:
I have my SDG2042X "improved" to 120MHz bandwidth successfully. The product type shown on system info now becomes "SDG2122X" and I am able to select the sine wave frequency up to 120MHz.
When I put the signal to oscilloscope for verification, the output waveform looks very good until 118MHz (for Channel 1) and 117MHz (for Channel 2) respectively. When I set the frequency higher than that, the frequency reads by oscilloscope doesn't increase much.
Not sure what really happens. Do I need a full calibration after hack to SDG2122X? Any hints?
Not sure what really happens. Do I need a full calibration after hack to SDG2122X? Any hints?What oscilloscope ?
What BW ?
What connection type is used ?
Are both units 10 MHz referenced ?
BTW, anyone has done a calibration/adjustment on SDG2042X?
I only found options under utility to calibrate the touch screen. Where is the internal self calibration?
