That work , Thank you a lot i go to sleep 2 jours before go to my job.
I have only this message, i dont Know why, but all seem work
If you or anyone had the following message:
"System concerns detected:
OS version is not correct. Please reload system firmware"
... then you should try another set of infiniivision.lnk file parameters. The scope likely had issue with a parameter mis-match
What worked for me (2000 series), and cleared the warning was:
80#infiniivisionLauncher.exe -l DIS -l MSO --perf -l BW20 -l SCPIPS -l CABLE -l VID
I also tried the following one successfully:
108#infiniivisionLauncher.exe -l DIS -l MSO --perf -l MEMUP -l BW20 -l ADVMATH -l SCPIPS -l CABLE -l VID -l EMBD
This one, for instance, created the OS mismatch nag/warning (I believe it was meant for the 3000A series):
160#\Secure\infiniiVision\infiniivisionLauncher.exe -l DIS -l MSO --perf -l MEMUP -l SCPIPS -l CABLE -l SGMC -l FLEXC -l TOM -l BW20 -l ADVMATH -l EMBD -l EDK -l VID
I used the USB memory stick option. Worked a treat.
