Agree when "less is more" comment especially on primary screen.
Random UI ideas across the top to save space if anyone also thinks worthwhile as you try to either gain space for new stuff, or lessen the overload:
- Clock could be placed within the menu to set time / debug screen. It's there to stamp images, we don't use the scope as a clock, so no need to appear front and center. I have enough devices that show me the time.
- Likewise, version could be removed from main screen. Though it is helpful for now as you take videos and screenshots addressing problems?
- Remove the Microsoft/Windows 8 styling from the Menu icon, the rest of the UI doesn't really use tiles so doesn't feel related. Consider either just using 3 line "hamburger" on a narrow button (giving even more space across the top), or additionally with Menu text to the right, but make it a bit narrower with the hamburger lines
- Move battery icon above new smaller RUN/STOP indicator, would even give a bit wider space to visualize percentage used (my image below I was able to scale the battery icon by 50% to align with Run)
- I'd like to do something about the sunburst icon and possibly move fast/slow as far as better positioning (though having more space and the button frame around the sunburst definitely helped), but haven't come up with any idea yet. Possibly between Menu and RUN may be better location as it's more "setup" and not specific to the trace itself like the others.
Thanks for all your continued work on everything!
Edit: Seeing the new post above mine, swapping time and battery icon would work better given width of adjacent text -- assuming you want to keep both time and version on the main screen. Then less space needed as Run indicator is narrower than the time while the battery is narrower.
But if you don't want to move the battery, then could change the version indicator to V.026k would also save horizontal width and make closer to existing width of battery
