Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1481763 times)
0 Members and 118 Guests are viewing this topic.
Offline ObsoleteDIY
  • Country: sk
  • Sometimes you can teach an old dog new tricks.
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #3750 on: April 06, 2026, 03:49:34 pm »
Hi Atlan,
the problems that appeared on AL3 with the new FW (spikes on the signal) were also during FW tuning on EF2L. On EF2L the problems were eliminated after changing the PLL phase shift setting from 90 to 45. :-//
Offline Atlan
  • Country: sk
« Reply #3751 on: April 06, 2026, 05:36:41 pm »
Yes, you're telling me about it, but it was already compiled, and I didn't get to the new one.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline ObsoleteDIY
  • Country: sk
« Reply #3752 on: April 06, 2026, 06:25:09 pm »
if you have time, you can upload the FW FPGA version 0x2011 for EF2L to the forum and a similar version 0x3011 for AL3. So that users can help us test the stability of the new FW for FPGA....PLL setting - phase shift 45 should be fine for FPGA EF2L FW 0x2011 If there are problems, we will return to version EFL 0x2000 and AL3 0x3000
« Last Edit: April 08, 2026, 07:40:36 pm by ObsoleteDIY »
Offline joker75
  • Country: am
« Reply #3753 on: April 12, 2026, 04:15:43 am »
"HELP! FNIRSI 1014D bricked. SPI flash (2MB) completely erased. Device uses Allwinner F1C100s CPU. I can access via xfel in FEL mode. Need full 2MB flash dump from working 1014D. Command to make dump: .\xfel.exe spinor read 0 2097152 flash_dump.bin Please share the file!"
Offline pcprogrammer
« Reply #3754 on: April 12, 2026, 06:19:51 am »
Hi and welcome to the forum. Did you look through this thread https://www.eevblog.com/forum/testgear/new-bench-scope-fnirsi-1014d-7-1gsas/ about the 1014D to see if the full binary is in it. I know that the flash content for the FPGA is in there and think the one for the F1C100s is also there, but it has been to long ago.
Edit: I found my post in that thread that has what you need: https://www.eevblog.com/forum/testgear/new-bench-scope-fnirsi-1014d-7-1gsas/msg4102147/#msg4102147
« Last Edit: April 12, 2026, 06:25:06 am by pcprogrammer »
Offline usatik33
  • Country: ru
« Reply #3755 on: April 16, 2026, 09:27:11 am »
Hello. Help please. I can flash the fnirsi_1013d firmware.bin v0.025d.txt , and the oscilloscope turns on normally. And if I flash fnirsi_1013d.bin v0.025e, or any other recent version, an error occurs when downloading--SD card program read failed.
2794949-0
« Last Edit: April 16, 2026, 09:30:58 am by usatik33 »
Offline Atlan
  • Country: sk
« Reply #3756 on: April 17, 2026, 04:23:49 pm »
What SD card do you have there? How much free space is available for the firmware? 2MB of special space is required.
Offline usatik33
  • Country: ru
« Reply #3757 on: April 27, 2026, 07:28:42 am »
Hello. I figured it out. The card was damaged. I bought a new one. Everything is fine. Please tell me, what is the latest firmware version without FPGA? It's currently v0.27u.
Offline waterstarrunner
  • Country: hk
« Reply #3758 on: April 30, 2026, 11:46:35 am »
I finally got to understand the input paths of this scope better to check out my problem
On channel 2, there's a linear offset between the A and B channels of the ADC. It's around 9% of the full ADC range.
Zoomed in on the horizontal resolution, any time where we're plotting individual samples, I'm seeing a perfect sawtooth wave... When I change the vertical resolution, the sawtooth amplitude on screen matches. Positive and negative DC offset don't seem to change the peak-to-peak of the sawtooth.
This causes the first stage of the calibration to fail for channel 2 (but it succeeds on channel 1).
Considering that the A and B channels of the ADC are tied physically for the A&B in #A&#B in, and the VrefA&VrefB, I can only assume this skew is internal to the ADC chip :(
Is there anything in the firmwares that can correct for this offset? Or am I close to the end of my 1013d journey? Or have I misdiagnosed my issue?
Offline Atlan
  • Country: sk
« Reply #3759 on: May 01, 2026, 05:30:52 pm »
try removing the resistor at the ADC ch2 input, and feed the signal from ch1 through a 220R resistor.
The following users thanked this post: waterstarrunner, mishail71
Offline Russell2024UK
« Reply #3760 on: May 04, 2026, 11:19:09 am »
Hi Atlan  :)
I’ve been away for a while and wanted to check—are you still providing a standard `.bin` firmware file for the 1013D oscilloscope (simple format)?
My current version is 0.26v9 . I came across a ZIP file, but it doesn’t clearly indicate the scope firmware (it’s not labelled simply as “scope” or similar), so I’m not sure if it’s the correct one.
Would you be able to confirm whether a `.bin` file is available, and if so, could you point me to the right file? Thanks in advance for your help  :-+
« Last Edit: May 04, 2026, 03:00:53 pm by Russell2024UK »
« Reply #3761 on: May 04, 2026, 03:08:13 pm »
Hello where is your .bin file stored for scope V1.00p0   ? mine is 0.26v9  thank you
« Reply #3762 on: May 04, 2026, 03:29:18 pm »
Can i use firmware 1.00o5 safely with normal DSO 1013D ? Thank You
« Reply #3763 on: May 10, 2026, 09:09:18 am »
Fnirsi 1013D oscilloscope LCD no display Repair FIX .. See our YouTube video Fnirsi 1013D oscilloscope LCD no display Repair FIX on
https://youtu.be/N471cSQgNYM
« Reply #3764 on: May 10, 2026, 06:04:11 pm »
Atlan  :) Could you supply a zip file location for scope v1.00p8.bin please ? :-+
« Reply #3765 on: May 11, 2026, 05:09:16 pm »
Try this download from Atlan new FPGA firmware with ALL17 for EF2 FPGA as a Zip file then open it this one gives you a 1013D simple firmware scope v1.00p7.bin ..  :-+
« Reply #3766 on: May 12, 2026, 08:18:14 am »
problem is needs a bmp image called scope then this issue ok Thanks Atlan ....  ...... would you know why my 1013D using firmware 1.00o5 normal scope - Says Failed to open file on bootup start ..  :-/O see my YouTube video ..
https://youtube.com/shorts/CjQuXbGgNiU    problem is needs a bmp image called scope then this issue ok ....
« Last Edit: May 14, 2026, 08:07:36 am by Russell2024UK »
« Reply #3767 on: May 14, 2026, 09:39:00 am »
Does anyone have an up-to-date PDF or Word document or location detailing the standard 1013D oscilloscope features and functions with the 1013D simple firmware scope from version 1.00p7? Thanks
Offline dougduck
« Reply #3768 on: May 14, 2026, 09:07:12 pm »
This was a bit confusing to me. It seems that the DSO firmware has a separate fork for the EF2 FPGA, which is not compatible with the AL3 hardware.
My device is the AL3 version, so I’m using DSO firmware version 1.00o8, since newer releases are not compatible.
This should be stated much more clearly to prevent people from accidentally bricking their devices.
ex:
FW FPGA EF2 v1.0
FW FPGA AL3 v1.0
FW DSO   EF2 v1.0
FW DSO   AL3 v1.0
The following users thanked this post: Russell2024UK
Offline GeorgyZ
  • Country: ua
« Reply #3769 on: May 15, 2026, 09:34:32 am »
Hi!
I have an Fnirsi 1013D based on the EF2L chip. I want to install new firmware and I have a few questions.
1. To flash the FPGA, do I need to follow the instructions at https://github.com/Atlan4/Fnirsi1013D/tree/main/Verzia%201.xxx/FPGA%20for%201.xxx/FPGA%20EF2, or can I do it from the ‘Update’ menu when starting the oscilloscope?
2. In the archive at https://www.eevblog.com/forum/testgear/fnirsi-1013d-100mhz-tablet-oscilloscope/?action=dlattach;attach=2789289 there is an FPGA.bit file, but this file type does not appear in the Update menu; only .bin files are shown. Is it possible to use this version, and how can I convert it to .bin?
Best regards!
« Last Edit: May 15, 2026, 10:00:09 am by GeorgyZ »
Offline Atlan
  • Country: sk
« Reply #3770 on: May 15, 2026, 01:42:45 pm »
To program EF2, you need a programmer and an installed IDE environment TD anlogic.
Offline Atlan
  • Country: sk
« Reply #3771 on: May 15, 2026, 01:46:08 pm »
ex:
FW FPGA EF2 v1.0
FW FPGA AL3 v1.0
FW DSO   EF2 v1.0
FW DSO   AL3 v1.0
The oscilloscope FW is definitely compatible with all FPGAs (except for the fnirsi fpga, probably). But it is quite possible that the fpga FW version for al3 is not up to date.
Offline Atlan
  • Country: sk
« Reply #3772 on: May 15, 2026, 07:13:35 pm »
scope v1.00p9.bin untested, I don't mind. Some changes for FPGA. AL3 has version 3014, EF2 version 2014
ObsoleteDIY mas tam zmeny  o ktorych sme hovorili v DSO FW
« Last Edit: May 15, 2026, 07:39:06 pm by Atlan »
The following users thanked this post: Russell2024UK, Etrius
« Reply #3773 on: May 16, 2026, 08:00:45 am »
What are the additions / updates made to firmware v1.00p9  for 1013D :-/O ?  :-+ for the standard DSO .... Thank you ...
Offline engineer.r152
  • Country: ru
« Reply #3774 on: May 16, 2026, 07:24:22 pm »
Good evening! Atlan, I have an oscilloscope with an AL3 device, I updated the program FPGA version 3014 and now it does not turn on, just a black screen, the relays do not click.
« Last Edit: May 16, 2026, 07:31:40 pm by engineer.r152 »
