Author Topic: New Keithley DMM6500 and now DAQ6510  (Read 304119 times)
splin and 4 Guests are viewing this topic.
Offline Joel_l
Re: New Keithley DMM6500 and now DAQ6510
« Reply #875 on: April 13, 2020, 03:38:36 pm »
I bought mine March 2019. I will see how it goes. I also leave mine plugged in. When I get to having to do mine, I will decide if I want to mess with it.
The following users thanked this post: jancumps
Offline thanasisk
« Reply #876 on: April 14, 2020, 10:29:30 pm »
Has anyone replaced the fan of their DMM6500? People have been complaining about that fan noise.  Saw pictures that it is a Sunon Maglev MF50100V2-1000C- (50mmx50mmx10mm 5V 25.6dbA 11CFM 0.11inchH2O). Too bad noctua doesn't yet produce their 50mm slim a series fan.
Offline KedasProbe
« Reply #877 on: April 16, 2020, 05:36:30 pm »
It may be easier to add a resistor in series with the fan, since they said it is blowing harder than needed.
About the Battery, the one at work is always powered but the one at home I disconnect due to the annoying hum. (We will see how that goes.)
Not everything that counts can be measured. Not everything that can be measured counts.
[W. Bruce Cameron]
Offline wn1fju
« Reply #878 on: April 17, 2020, 12:03:37 am »
1.38V on my old battery, 20 months old, unit disconnected from power at the end of each day.
Hardest part of the replacement was getting the four screws out to remove the case.  They are in there tight.
Offline Mr. Scram
  • Display aficionado
« Reply #879 on: April 17, 2020, 05:09:03 pm »
Does anyone here use the Kickstart software with these and is it worth the trouble? It seems to add not that much but perhaps I am mistaken.
Should I interpret the overwhelming lack of response as an equivalent lack of enthusiasm for Kickstart?
Offline thm_w
  • Non-expert
« Reply #880 on: April 17, 2020, 09:34:01 pm »
We might not be able to move the location of the battery, but I will have us investigate whether or not a better Vendor / type of battery could be used and what is the cause of the drain - might also be able to be improved.
Its highly unlikely to be an issue with Panasonic cells, I've seen thousands and only a few died prematurely. The rest of those products last for 10 years+ (RTC current is 3uA, ~9uW).
Measure the quiescent current and it should tell you right away if it is a design issue.
MPC5125 has an internal RTC but I'm not sure if that is being used as it notes a 3V minimum input.. That is right on the edge of what a CR2032 will provide. Odd voltage for them to choose.
https://www.nxp.com/docs/en/data-sheet/MPC5125.pdf
MPC5125 power is rated 20uW (not sure if thats worst case or typical).
CR2032 = 220mAh = 0.66Wh/20uW = ~3.8 years
Maybe there is some additional leakage from Vbatt GPIO or diodes.
Offline KedasProbe
« Reply #881 on: April 18, 2020, 07:07:40 am »
I do have it (it was free) but I find myself not using it. (I only have the DMM6500 for it)
I use the screen of the DMM and if I want to see/control it on my PC I use the webinterface (does not work for digitizing), and if I want the data I just save the buffer.
It could be more interesting when you have more than one keithley device in Kickstart or multi-channel.
« Last Edit: April 18, 2020, 07:24:31 am by KedasProbe »
[W. Bruce Cameron]
The following users thanked this post: Mr. Scram
Offline Wintel
« Reply #882 on: April 18, 2020, 02:47:26 pm »
I buy KickStart license some time ago(~2 year), and use it for my 2450 SMU and DMM6500, but not frequently.
It's a good software. I like it much more Keysight BenchVue. I will never buy BenchVue.
I don't remember price, but is not too high - forever use is 200-300 bucks or so....
As i hear in this topic - when you buy DMM6500 a Keithley grant KickStart for free. :-+
After buying license i created my own data logger software. But KickStart is still good for I/V curve on 2450. I don't regret about buying KickStart, in future i planned buy more Keithley SMU's, it will be very-very helpful.
Latest version 2.2.1 are fixed many bugs. It's  useful version.
I recommend it :-+ :-DMM
3 Year or lifetime KickStart license?
Offline Wintel
« Reply #883 on: April 20, 2020, 04:53:27 pm »
Update on the battery Issue:
There was a clock running that was supposed to be shut down by firmware while in standby mode. This prematurely drains the battery.
Next Firmware 1.7.3 resolves this problem - I was told released in a couple of months.
For those of you replacing it on your own, please be careful as the holder has a very fragile clip that might break during the replacement.
Thanks
Can send DMM6500 to Keithley service center to replace the battery free of charge?
Offline KedasProbe
« Reply #884 on: April 21, 2020, 06:07:09 pm »
Thanks
So we can assume that the battery is not extra drained when the power cord is unplugged.
Meaning it's better to disconnect the device when not used until a new firmware is available?
[W. Bruce Cameron]
Offline KedasProbe
« Reply #885 on: April 23, 2020, 12:13:53 pm »
Drains anyway....
Well the good news about that is that you know when and how many people will start complaining in the coming months. You may want to prepare: "Press 9 if it's about the battery"  :P
I purchased a bit more than a year ago so I still have some battery left over.
[W. Bruce Cameron]
Offline hoooooonza
  • Country: cz
« Reply #886 on: April 24, 2020, 06:29:50 pm »
Hello,
I am considering buying DMM6500 for measuring IOT devices - mainly sleep currents and the transitiosn to the active modes. I saw some videos and I like DMM6500 digitizer function. Can someone tell me if it is good instrument for this purpose? I read a lot about bluescreens, RTC backup battery troubles etc.. so I am little bit worried.. But there are not many competitors on the market.
Main competitors:
https://www.qoitech.com/products/standard - nice desktop application, many interesting functions. But sampling is very slow (4ksps) so I am afraid it doesn't catch short spikes an also voltage output is <=5V.
https://www.anglercircuits.com/ - interesting product, but the GUI is not as advanced as Qoitech one. Same proble with voltage output range <=6V.
For IOT development we can live with voltage range 0-5V, but sometimes we do stuff for automotive an there are units with 12-24V input so would be great to have one instrument for everything.
Is is possible to use digitizer in Kickstart app? Does Keithley have any tool for working with graphs taken by DMM6500? (I mean I will record data, store them to USB and then I can do some measurments on PC).
We have budget 2k USD.
Thank you,
Jan
Offline cgroen
    • Carstens personal web
« Reply #887 on: April 24, 2020, 06:32:37 pm »
I have 2 DMM6500 and love them.
But for characterizing powerconsumption on CPU's, wireless devices etc etc, I would never use anything else than my Joulescope. So much better suited for this purpose.
The following users thanked this post: MegaVolt
Offline hoooooonza
  • Country: cz
« Reply #888 on: April 24, 2020, 06:43:39 pm »
Thank you for quick answer. I saw review from eevlog - did thy fix all the mentioned problems? It was mainly in GUI as far as I know.
Offline cgroen
« Reply #889 on: April 24, 2020, 06:49:00 pm »
Yes, and there are updates often, new features etc
Also very open minded about suggestions from users!
Offline MegaVolt
  • Country: by
« Reply #890 on: April 24, 2020, 09:44:22 pm »
You can take a look at the process of writing a buffer live.
Offline hoooooonza
  • Country: cz
« Reply #891 on: April 25, 2020, 12:08:47 am »
It really takes 50 sec to get the graph? Or did they improve this in the latest FW? :-/O
Thank you,
Jan
Offline MegaVolt
  • Country: by
« Reply #892 on: April 25, 2020, 12:43:47 pm »
I can say that in the new version for 7510 it became even slightly worse:
https://forum.tek.com/viewtopic.php?f=363&t=142031
It seems that this is not a key function of the device. This is still a multimeter. Data is transmitted to the computer at a speed of 60 kS / s.
Perhaps this will all be fixed someday. But the device has been over 5 years old and I don’t see them greatly improving this function.
Offline hoooooonza
  • Country: cz
« Reply #893 on: April 25, 2020, 07:47:39 pm »
Okay, thank you. I will check Joulescope then :)
Jan
Offline Mr. Scram
« Reply #894 on: April 28, 2020, 08:01:41 pm »
How loud is the fan on these? Needing active cooling instead of the passive cooling of the 34401A and Keithley 2000 seems a huge step back.
Offline jancumps
  • New Low
« Reply #895 on: April 28, 2020, 08:14:12 pm »
not loud. For me no issue while on my bench.
« Last Edit: April 28, 2020, 08:49:17 pm by jancumps »
Offline jancumps
  • New Low
« Reply #896 on: April 28, 2020, 08:51:02 pm »
I'm in the hear it but not bothered by it camp. It isn't intrusive in my opinion, working in a fairly silent place.
The following users thanked this post: thm_w, shodan@micron, Mr. Scram
Offline KedasProbe
« Reply #897 on: April 29, 2020, 07:03:22 am »
You can obviously hear it, otherwise you need to see a doctor.
My colleagues ask me to turn it off when I'm not using it due to the noise. (2-3 meters away)
Although I don't think it's very annoying, you do get the feeling "ah much better" when the noise is gone.
And if you are alone in a silent office you may also be bothered by the hum, I find that more annoying, I can hear that hum as soon as I enter the room but when the fan is on the hum isn't obvious anymore.
That is also the reason why I disconnect the power line when I don't use it. So the standby button is more a reboot button for me.
Having some music playing helps to forget the noise.
P.S my monitor or tablet do not have a noisy fan, even my laptop isn't making a sound now, not even a power adapter hum, it's certainly possible to design it silent but I guess then it will cost more or maybe they didn't care about it very much 'good enough state of mind'
« Last Edit: April 29, 2020, 07:40:28 am by KedasProbe »
[W. Bruce Cameron]
Offline HendriXML
    • KiCad-BOM-reporter
« Reply #898 on: April 29, 2020, 08:54:48 am »
Before disconnecting the power line, does one need to bring it in standby mode first?
I also disconnect it, but bring it in standby mode first, I was wandering this is really necessary.
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Offline KedasProbe
« Reply #899 on: April 29, 2020, 02:11:52 pm »
I do put it in standby first before disconnecting in case there is some shut-down sequence or relays.
[W. Bruce Cameron]
