Author Topic: Siglent SDG1000X Waveform Generators  (Read 93209 times)
Offline Ringmodulator
Re: Siglent SDG1000X Waveform Generators
« Reply #325 on: April 20, 2024, 07:30:00 pm »
I have just updated to the new FW.
A quick check showed, that it looks like the external clock issue is solved.
I have not checked for other issues.
Chris
The following users thanked this post: Wrenches of Death
Offline diodak
« Reply #326 on: April 20, 2024, 07:59:41 pm »
The font has also been changed, unfortunately to an even smaller one... Probably for better screenshot quality (added under the Store/Recall button).
Offline eTobey
« Reply #327 on: May 15, 2024, 07:57:56 am »
I just received my SDG1032X today.
I was looking for an option to limit the leves, but i only could find amplitude limit. I guess am just blind?
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
Offline tautechTopic starter
« Reply #328 on: May 15, 2024, 08:21:00 am »
P102
https://int.siglent.com/u_file/download/22_06_23/SDG1000X_UserManual_UM0201X-E01E.pdf
Offline eTobey
« Reply #329 on: May 15, 2024, 01:39:34 pm »
P102
I can not find a limit on page 102, neither the page the viewer shows, or what page is written on the pages.
Offline Njk
  • Country: ru
« Reply #330 on: May 15, 2024, 02:18:28 pm »
I'm afraid a separate thread will be created soon, labeled "Siglent Rubbish SDG1000X - An expensive piece of Junk"
Offline Mortymore
  • Country: pt
« Reply #331 on: May 15, 2024, 03:29:38 pm »
 :popcorn:
Offline eTobey
« Reply #332 on: May 15, 2024, 03:41:21 pm »
So? do you actually know this device?
« Reply #333 on: May 15, 2024, 09:25:13 pm »
P102
Levels are dictated by the load the AWG is connected to and the Output setting, HiZ or 50 Ohms.
Datasheet specifies 20V p-p into HiZ and 10V p-p into 50 Ohms.
Is it something else you seek ?  :-//
Offline BillyO
« Reply #334 on: May 16, 2024, 02:32:31 am »
The AWG is always physically set at 50ohms out.  The output setting just changes the how the voltage is displayed by the AWG and not the voltage actually output.  Right?
I was going to ask him the same question. :-DD
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline eTobey
« Reply #335 on: May 16, 2024, 06:57:56 am »
I want to test my microcontroller without destroying it. But this thing is almost as bad as the Rigol... Just the knob is a slighly better, and it has a keypad.  :palm:
« Reply #336 on: May 16, 2024, 07:20:39 am »
Without knowing how to use any tool correctly you cannot blame the tool for mistakes an operator user makes.
Offline eTobey
« Reply #337 on: May 16, 2024, 07:23:55 am »
A proper tool should have some safety build in, because mistakes can be made by the best specialists too! This is especially likely, if the GUI is suboptimal  :palm:
Online 2N3055
  • Country: hr
« Reply #338 on: May 16, 2024, 07:29:25 am »
Do you EVER read anything or research ANYTHING about things you are going to to buy before you buy it?
Do you ask for advice or recommendation BEFORE buying anything?
Or you just buy random thing and then expect that it magically has all the properties that you imagine it should have in your wild imagination ?
There is no definable setable amplitude limit on these AWG. Not on SDG1000X, not on SDG2000X, not on SDG6000X. Nowhere it claims so or anyone ever told you so.
Destroying DUT with AWG is not something that I 'we seen in practice that often, normally.
More likely is that you will destroy AWG backfeeding high voltage/current from your device back into AWG output.
That I have seen.
For that occasion , SDG1000X/ 2000X/ 6000X have output protection that disconnects output if it detects backfeeding of current into output. With enough energy people damaged AWGs even with protection.
Eventually, it is your responsibility to not do stupid things.
SDG7000A has both protection and setable output limits. But it has setable output  limits because it can generate very high voltages/currents on outputs that are capable of destroying something.
The following users thanked this post: Performa01
« Reply #339 on: May 16, 2024, 07:34:54 am »
That I have seen.
It's all okay.
We all know that owning a new instrument for 2 days makes us an expert on it, right ?  :-DD  ::)
Online Martin72
  • Testfield Technician
« Reply #340 on: May 16, 2024, 07:40:41 am »
Not quite, but it didn't take long.
The following users thanked this post: tautech, TurboTom, newbrain
Online 2N3055
  • Country: hr
« Reply #341 on: May 16, 2024, 07:41:30 am »
That I have seen.
It's all okay.
Oh don't you worry...
He already made a new topic "Siglent SDG1032 as bad as rigol DG812?"...
|O |O
Offline newbrain
« Reply #342 on: May 16, 2024, 08:47:13 am »
I now understand how a bowl of petunias can feel.
The following users thanked this post: TurboTom, 2N3055, Mortymore, Martin72
Offline BillyO
« Reply #343 on: May 16, 2024, 02:45:12 pm »
So you want current limit?
I'd still like to see a circuit of what you have in mind.  :-//
It seems to me, if you set the AWG output correctly (as an example: HiZ with 5Vpp + 2.5V offset) and feed it into an input on the MCU there should not be any destruction unless the MCU itself is faulty.  Even then the output of the AWG is limited to 200ma.  The AWG will protect itself under most conditions unless you are doing something truly barbarous.
If you cannot bring yourself the set the output of the AWG correctly, put a resistor in line to reduce current further.  :scared:
Online Martin72
« Reply #344 on: May 16, 2024, 03:05:29 pm »
Build your own...
The following users thanked this post: Grandchuck
Offline Performa01
  • Country: at
« Reply #345 on: May 16, 2024, 06:33:23 pm »
At least SDG6000X has these features as well. You can enable the output amplitude limit:
Utility -> Output Setup -> Amplitude (on page 2); it can be set as low as 2 mVpp for the High-Z configuration.
I don't have an SDG2000X here, but wouldn't be surprised if it had the exact same feature.
And who knows? Maybe even the low end SDG1000X series have it. This is just one of the features that never made it into the user manuals of the lower end products. But I think it's more important that it made it into their firmware anyway... ;)
« Last Edit: May 16, 2024, 06:48:55 pm by Performa01 »
Online Martin72
« Reply #346 on: May 16, 2024, 06:41:51 pm »
Confirmed. ;)
The following users thanked this post: Performa01, 2N3055, KungFuJosh
Offline mawyatt
« Reply #347 on: May 16, 2024, 06:47:50 pm »
Utility -> Output Setup -> Amplitude (on page 2); it can be set it as low as 2 mVpp for the High-Z configuration.
SDG2042X also has this feature!
Best,
~Wyatt Labs by Mike~
Offline BillyO
« Reply #348 on: May 16, 2024, 06:48:35 pm »
It's on the SDG1000X series too:
« Last Edit: May 16, 2024, 06:51:17 pm by BillyO »
The following users thanked this post: Performa01, tautech, 2N3055, Martin72
Offline BillyO
« Reply #349 on: May 16, 2024, 06:55:29 pm »
There also seems to be an option in the 2nd page of the Utility menu called "OverVoltage protection" and you can turn it on or off.  It does not seem to be covered in the manual.
Actually, it is:  Page 121.  I misspelled "OverVoltage" when I did the search fist time. :palm:
« Last Edit: May 16, 2024, 07:03:03 pm by BillyO »
