Author Topic: Siglent SDS800X HD 12 bit DSO's  (Read 1207562 times)
0 Members and 39 Guests are viewing this topic.
Offline KungFuJosh
  • TEAS is real.
Re: Siglent SDS800X HD 12 bit DSO's
« Reply #1775 on: November 29, 2024, 01:29:58 am »
Ground clip should definitely be attached properly for probe compensation.
Set to default, update to latest firmware if not already, set to default again, warm up, then run self cal.
Best Continuity Tester Ever
Offline ttelectronic
« Reply #1776 on: November 29, 2024, 02:23:04 am »
I am about to buy an SDS804X HD.  I'm sticking with the 70 MHz version, at least partially because this  thread makes it seem like it is possible to "upgrade" to the SDS824X HD by just changing the identifying string in the scope (not that I can find the instructions on how to do this for the life of me!).  The price point is also fantastic, of course!
I am aware that the probes that come with the 70 MHz scope will be lower bandwidth than the higher bandwidth models (and also, apparently, missing ground springs).
What I am very curious about is the following:
1. Have people actually had real/measured success with the "soft upgrade" on these scopes?
2. Is there a CPU-like "silicon lottery" here? i.e. Do some scopes upgrade better than others, and some not at all? Is there luck involved?
3. Is there any risk involved with doing the soft upgrade (aside from voiding warranty)?
4. Are there any other changes that result from the soft upgrade, other than the higher bandwidth and reported model not matching the faceplate label?
5. How is Siglent downgrading the scopes... are they running a DSP filter? It is interesting if they do (and I hope it is a FIR for constant group delay!!)
I'll be buying the SDS804X HD regardless, since the price point is just right for 4 channels... but I would definitely appreciate any insights into the rumoured upgrade process!
Also - first post! :D
I am not sure about warranty.  I did find this video useful for bandwidth info.. =)
Offline Performa01
  • Country: at
« Reply #1777 on: November 29, 2024, 11:08:41 am »
...  I did find this video useful for bandwidth info.. =)
Yet this bandwidth-demonstration is rather flawed in all possible ways. The good news is that the actual probe bandwidth will most likely be even higher than the claimed 215 MHz.
1.   The signal source should be a levelled signal generator with a amplitude flatness of ideally better than +/-0.5 dB. The tracking generator of a cheap Tiny SA (where the frequency response hardly matters, as it will be normalized before each SNA measurement anyway) hardly qualifies as a trustworthy signal source for bandwidth measurements.
2.   The signal source has to be terminated into 50 ohms, i.e. there has to be a 50 ohms inline terminator between generator and probe, making the total source impedance 25 ohms. From the video, I cannot clearly see if a terminator is present, but if not, then this means a -3 dB point of the signal source at about 270 MHz already. With the industry standard 25 ohms source impedance, it is twice as high.
3.   What has been shown in the video, is the system bandwidth of a SDS2505X Plus together with the probe – not the probe bandwidth. Even at only 200 MHz, there will be small deviations in the frequency response of a “600 MHz” (actually 570 MHz) oscilloscope.
4.   Actually, the probe builds a unit with the input buffer of the DSO-frontend and we always need to look at the combination of the two. Since the frontend of an SDS2000X Plus is clearly different to the SDS800X HD series, there’s o guarantee that the performance of the probe will be the same in both cases.
5.   The shown way with pocket calculator and level measurements at just a few frequencies is a rather clumsy and inaccurate one – especially when taking the low-quality signal source into account. Why not take advantage that these scopes (other than some competition) do have a usable FFT with Max Hold and Average modes and correct window functions, to present the measurement in a precise and comprehensive way?
If one doesn’t have the equipment to meet the requirements listed above (usually the biggest challenge will be a proper high quality signal generator), the best approach to get meaningful results is comparing a direct coax connection with the probe. This way, the frequency flatness of the signal source becomes less significant.
We would start with a direct connection (using a high quality low-loss coaxial cable as short as possible) between signal generator and 50 ohms oscilloscope input. There should be an at least 10 dB inline attenuator between generator output and cable, in order to improve the VSWR, hence the ripple in the response curve, which is usually rather bad for most (even expensive) signal generators.
Here the first problem arises with an instrument that doesn’t provide 50 ohms input impedance. The next best thing is to place an inline terminator at the scope input, but then we have 50 ohms in parallel to about 22 pF instead of pure 50 ohms, which will naturally have a negative impact on the frequency response.
We plot the frequency response using FFT in Max Hold mode and store the result as a reference waveform. Then we perform the probe test as described earlier in this article, i.e. the inline terminator is moved from the scope input to the generator output. The attenuator is now removed (if we had used a 20 dB attenuator for the direct coax measurement, we would now get the exact same levels without attenuator using a 10x probe). Then we can compare the two curves and determine how well the probe performs over the entire frequency range.
All this has been explained numerous times, also in this very thread, if one can be bothered to use the forum search and look it up:
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5403110/#msg5403110
In fact, the following link contains all that’s needed to know:
https://www.eevblog.com/forum/testgear/sds800x-hd-review-demonstration-thread/msg5351024/#msg5351024
The measurements for the SDS824X HD have been carried out with an old 100 MHz PP510 and a 500 MHz PP5050A probe, using a proper signal source with better than 0.3 dB flatness. We can see that the frequency response actually begins to drop at about 120 MHz, but only ~1.5 dB, and then stays relatively flat up to some 270 MHz.
“270 MHz isn’t much more than the 215 MHz from the video, and this is a 100 MHz probe instead of just 70, some might think. The main fact is that this bandwidth has been reached with the SDS824X HD, not an SDS2504X Plus. The SDS824X HD has about 250 MHz bandwidth when using a direct coax connection, so the 100 MHz PP510 actually extends the system bandwidth. Compare this with the claims from all those textbook-afficionados, who will insist that the combination of a 100 MHz probe together with a 200 MHz scope will give you a system bandwidth of just 90 MHz…
I firmly believe that the 70 MHz probe will behave nearly identical (the PP215 certainly does). In general, a probe with higher bandwidth rating will not give much of an advantage, especially when considering the limited usability of high-Z passive 10x probes at frequencies above some 100 MHz (due to high capacitive load). If you have such a low impedance circuit node, it is still better to make this a 50 ohm test port and use a direct coax connection once again. If the node is high impedance, then you’re out of luck and might need an active probe solution. Best way is to design proper 50 ohms test points into your circuit right from the start.
The 500 MHz PP5050A performs barely better than the cheap PP510. The 1.5 dB drop at 120 MHz is there as well (so this might be a property of the frontend) and the -3 dB bandwidth is only insignificantly higher at ~290 MHz.
« Last Edit: November 29, 2024, 11:13:09 am by Performa01 »
The following users thanked this post: egonotto, newbrain, 2N3055, Martin72, Furna
Offline BillyO
« Reply #1778 on: November 29, 2024, 04:31:05 pm »
Yet this bandwidth-demonstration is rather flawed in all possible ways.  blah, blah, I'm great, blah, blah, look at how much I know, blah, blah...
Are you serious, for a quick 11 minute video? :palm:
Plus you make a lot of incorrect assumptions just to try to explain what a wonderful genius you are.  I know who did this video.  A terminator was used in the probe test.  The Tiny SA was tested over the applied range to be within 1db, and his 2504 has been verified to over 600MHz, not just 570.
He did a video precisely on this in the past.  Maybe you should get to know someone and pay a little attention to intent before you damn them.
In any case, this is obviously just a quick check and not claimed to be an attempt to characterize the probe or the scope with 100% certainty.  He mostly does videos for the average hobbyist using the equipment they are likely to have.  Not for the rare person with a $50,000 function generator to show off.
There are just too many petty snobs on this forum more than willing to fluff their feathers.
Time for me to give it a break.
« Last Edit: November 29, 2024, 04:34:38 pm by BillyO »
Bill
The following users thanked this post: egonotto, ttelectronic
Offline neosunrise
« Reply #1779 on: November 29, 2024, 04:49:27 pm »
Thank you both for the suggestions! I performed multiple self-calibrations after letting the oscilloscope warm up, but the issue persisted. I conducted some additional experiments and discovered a few interesting findings:
1. When I moved the probe cable around or use my hand to hold the cable, the oscilloscope sometimes triggered properly. I also noticed the noise on the top of the square wave would change, getting higher or lower depending on the cable's position.
2. When I connected the probe to other signal generators, such as the ZOYI 703S and Wavetek 270, no issues occurred, regardless of how I moved the cable.
3. Testing the oscilloscope’s internal square wave signal generator with other oscilloscopes showed no problems.
4. All my initial tests were conducted on the second floor of my house, where other oscilloscopes, including a Hantek DSO5102P, ZOYI 703S, and a budget DSO 150, worked perfectly without any issues.
5. When I moved the SDS804X to the basement, the problem disappeared entirely. However, I did notice that touching the probe cable still affected the noise on top of the square wave.
These observations make me wonder: Is my oscilloscope unusually sensitive to environmental noise? Why do my other oscilloscopes perform without any problems in the same conditions?
I tried but it didn't make any changes. Thanks for the reply though.
The only other thing I can suggest is do teh following:
1) Remove all probes.
2) Set the system to default configuration.
3) Run self calibration.
4) Try again (with ground clip attached).
You'll find the default setting and self calibration in the Utilities menu branch.
Self calibration takes a while to run.  Go get a drink.
Offline 2N3055
  • Country: hr
« Reply #1780 on: November 29, 2024, 06:16:50 pm »
Are you sure author of the video did use terminator in this video? It looks like simply SMA to BNC adapter into BNC adapter on the probe....
And even if that is some SMA/BNC adapter with built in terminator, 50 Ω signal source loaded with 15-20pF (from passive probe), even when properly terminated will cause significant voltage drop on the output of generator.
Fact that some signal source when properly terminated with 50Ω has 1dB amplitude flatness in BW in question, does not mean it will have that type of amplitude/frequency response when loaded with 20pF.
500 mV P-P, 200MHz signal from 50 Ω signal gen, terminated with 50Ω (so 25Ω source impedance) will drop to 435 mVP-P when loaded with expensive 500MHz 10pF probe. With 13pF 300Mhz probe generator output  drops to 418mV P-P.
That is from probe loading alone, at 200 MHz.
That is why leveled gen must be used to make sure gen level stays the same, once you go over, say, 100-150 MHz.
So I agree that this is not a way to measure passive probe frequency response. In a same way as you cannot really verify accuracy of 6.5 digit DMM with homemade voltage reference based on TL431. So just don't.
All so much as Performa did perform very thorough and proper measurement previously with several probes and proper technique and shared his results with us that do not have all this equipment.
Fact that you didn't like his tone I'm not gonna touch. That is a personal matter of perception, and both of you are big boys..
Dr. Richard W. Hamming
The following users thanked this post: egonotto, BillyO
Offline BillyO
« Reply #1781 on: November 29, 2024, 06:52:33 pm »
I am not saying Performa01 said anything "incorrect" and I do think he is a very capable engineer.  His rundown of the SDS824X HD was impressive enough that I bought one when I didn't really need one.  What I am saying is that this video was obviously not intended to be the ultimate in accuracy.  It's as if what the guy actually said is being ignored.  if you listen he was responding to someone commenting on the previous video saying that the Siglent probes are crap.  He was just quickly showing a way the average guy can verify they are not.  I'm totally missing the part where he said the method used was the be-all and end-all.  It certainly got in the ball park even if it did underestimate things a little, but the point was shown.
So, let's get to the real point of my little rant.  Performa01's comment is just one.  If we are to take his, yours just now ("Just don't") and hundreds of others I've seen on this site seriously, we are basically left with "Unless every piece of test equipment in your lab costs more than the average small car, and unless you follow methodologies approved by the IEEE (or whatever is most applicable), then - no electronics for you - just don't". :scared:
You see it all the time.  Some poor guy comes and asks a question, then the first "expert" jumps all over him rather than offering any expert advice, then comes the 3 pages of "expert" in-fighting, giving us the net result - the OP never returns.  Happens nearly every day.
It's just gets to be a little much.
« Last Edit: November 29, 2024, 06:57:08 pm by BillyO »
Bill
The following users thanked this post: egonotto, watchmaker
Offline IC_Toaster
« Reply #1782 on: November 29, 2024, 09:08:15 pm »
I have seen too much fights in this forums.
For me, someone who is hard to understand English, following threads is tiring when there are fights. Too much comments to ignore or not to ignore because maybe the discussion is due to a wrong argument, so I must not jump over these comments). I feel forced to read the fight in order to get the information I am searching and understand what is happening.
What is users problem with others?
Offline Grandchuck
« Reply #1783 on: November 29, 2024, 09:26:49 pm »
People who have worked hard, studied, experimented, and amassed sometimes amazing home laboratories are rightfully proud.  Thus, they can sometimes be a bit overzealous on this forum.  Or, language subtleties come into play and feelings are hurt.  Some of that is unavoidable.
This forum is tame compared to most.  I use it a lot and come here to learn and share.  Actually, there are very, very few jerks and trolls here.
The following users thanked this post: egonotto, hp lee
Offline 2N3055
  • Country: hr
« Reply #1784 on: November 29, 2024, 09:39:22 pm »
I definitely understand the frustration.. I get it.
But some things are just incorrect.
There are ways though that can be used that could provide better results... Without fancy equipment.
You could feed the gen into one side of a T and center of the T through the terminator towards scope into Ch1 (better would be 50 Ohm scope input but we don't have that).
Other side of the T is where you connect passive probe and run it to some other channel, say CH3 (not to be too close to T contraption).
Now you have 25 Ω source impedance and scope is monitoring on CH1 what is the signal on passive probe tip. Loading is even worse than before (cca. twice the capacity) but we don't care.
Then you setup Gen to some smaller frequency say 10 MHz and set scope to show same signal on both channel. Set say, 100mV RMS
Go to channel deskew and make sure signals are on top of each other (there will be phase difference because of passive probe additional delay).
And then you can set math channels where you  plot peak hold FFT for both Ch1 and CH3.
Run the frequency sweep.
Set Y1-Y2 cursors to measure FFT of ch1 and ch3 and just go over frequencies and jolt down in an Excel table several Freq,CH1 and CH3 amplitude for that datapoint.
Take 10-20 points,  it is really quick.
Then you need to normalize data.
Divide 100mV RMS (nominal voltage) with CH1 for that frequency point and then multiply CH3 data with that normalization factor. Rinse and repeat.
What you get is corrected data for difference between signal applied to CH1 and what arrived on CH3.
I.e. a probe/scope input combined freq response.
Convert to dB.
Or do measurement/calculation in dB in first place, which means it is not divide/multiply anymore but simple add/subtract.
« Last Edit: November 29, 2024, 10:25:18 pm by 2N3055 »
The following users thanked this post: egonotto, BillyO, ttelectronic
Offline hp lee
  • Country: kr
« Reply #1785 on: November 29, 2024, 09:47:19 pm »
When I switched the probe to 1X and ran "AUTO SETUP" again, it triggered correctly. However, switching back to 10X caused the waveform to continue moving across the screen. Note that I only used the auto-setup feature and did not attempt to trigger manually. Auto-setup simply didn’t work in this scenario.
Same result on all four channels/probes?
Offline neosunrise
« Reply #1786 on: November 29, 2024, 09:56:57 pm »
Yes and I provided some updates in my post above as well.
« Reply #1787 on: November 30, 2024, 12:16:53 am »
My intention was not to try and get someones methods ripped apart but to provide the person asking a question with a video of someone answering that question in the way that they are able. I've looked, and I haven't been able to find anyone else attempting to to check the combination bandwidth on a video.
I hope we can all at least agree that
1) upgrading the 804x to an 824x works
2) the PB470 probes that comes with the 804x are probably sufficient enough for the upgraded scope
Offline egonotto
« Reply #1788 on: November 30, 2024, 02:08:54 am »
Hello,
can you take a closer look at the signal? Use the single trigger with enough memory and then look at a few edges with sufficient time resolution. Then you might be able to see the reason for the trigger behavior.
Best regards
egonotto
« Last Edit: November 30, 2024, 02:11:50 am by egonotto »
Offline magic_smoke
« Reply #1789 on: November 30, 2024, 01:41:35 pm »
Can someone confirm the Memory depth of a hacked sds804x?
Does it go to 100Mpts?
Online ebastler
« Reply #1790 on: November 30, 2024, 01:46:42 pm »
Yes, it does.
The following users thanked this post: magic_smoke
Offline neosunrise
« Reply #1791 on: November 30, 2024, 06:59:22 pm »
Hello,
Best regards
egonotto
It seems that the noise were coming from the power cable - when I moved the probe or the wire close to the power cable, the noise picked up significantly. I set the bandwidth to 20MHz and the scope was able to successfully trigger. I'm wondering if this is normal? I mean, why didn't my Hantek DSO5102p need to set the bandwidth to 20MHz for a successful trigger in exactly the same environment? Is it because the SDS804X is much more sensitive to tiny signals than DSO5102p?
« Last Edit: November 30, 2024, 07:10:46 pm by neosunrise »
Online tautechTopic starter
« Reply #1792 on: November 30, 2024, 07:23:23 pm »
Hello,
Best regards
egonotto
Possibly.
Do you have the scope connected to mains that provides a protective earth connection ?
If not the BNC's will be floating whereas they should be at mains earth potential.
Avid Rabid Hobbyist
Offline neosunrise
« Reply #1793 on: November 30, 2024, 10:06:40 pm »
Hello,
Best regards
egonotto
Possibly.
I can’t say for sure, but I measured the voltage between live and earth (not neutral), and it was about 120V, so I assume the oscilloscope is properly earth-grounded.
Another observation: when the SDS804X failed to trigger, I noticed that the vertical sensitivity was automatically set to 100mV/div. However, when I manually adjusted it to 500mV/div, the oscilloscope was able to trigger correctly.
I also tested this behavior on my DSO5102P. When it auto-triggered, the vertical sensitivity was set to 2V/div, which is much coarser than the SDS804X’s default. Interestingly, when I manually adjusted the DSO5102P’s sensitivity to 500mV/div, it couldn’t hold a stable trigger either.
From these experiments, it seems like the Hantek’s auto-setup program correctly sets a coarser sensitivity level to ensure a stable trigger, whereas the SDS804X’s auto-setup program appears to pick an overly fine sensitivity level, potentially timing out before finding a stable trigger point.
At this point, I’m not sure if my understanding is reasonable or if the SDS804X has an internal fault causing this behavior.
« Last Edit: November 30, 2024, 10:17:01 pm by neosunrise »
« Reply #1794 on: November 30, 2024, 11:05:24 pm »
Hello,
Best regards
egonotto
Possibly.
Probably some noise going on that you haven't homed in on yet.
Set some Persistence from within the Display menu and see what turns up.
Avid Rabid Hobbyist
Offline Piranha
« Reply #1795 on: December 04, 2024, 10:29:25 pm »
I just got my 804
Man this fan is loud! I can even hear it running if I stand on the opposite of my apartment which is 2 rooms and one hallway between me and this fan. Is there supposed to be a fan control? because it stays this way the second I turn it on. There is no way that I can leave it on while doing some other stuff.
Online ebastler
« Reply #1796 on: December 04, 2024, 10:51:10 pm »
I just got my 804
No, the fan is not temperature-controlled. Its noise level is par for the course in this scope class, which needs to remove 30 to 40W of heat via a relatively small fan. Some users have modified their scopes by installing a slightly quieter fan (with different blade geometry) and reducing the fan speed via a series resistor -- just don't overdo it.
There is a big variance in personal expectations and sensitivity to noise. What kind of scope did you have before?
Offline Martin72
« Reply #1797 on: December 04, 2024, 11:03:14 pm »
Indeed.
I am always amazed at how differently people react to noise, but a lot also depends on the environment.
At work, in our laboratory, an SDS800X HD would not be noticeable because there are enough “working noises”.
In a quiet room, of course, you can hear it immediately.
« Reply #1798 on: December 04, 2024, 11:05:12 pm »
I just got my 804
Welcome to the forum.
Upgrading to SDS2000X HD would please you....they are really quiet.
Avid Rabid Hobbyist
The following users thanked this post: Bad_Driver, Piranha
Offline Martin72
« Reply #1799 on: December 04, 2024, 11:26:06 pm »
You're understating it, Rob.
They're dead. 8)
