Here are some further notes regarding the DSA815 with bootloader 1.04 and firmware 1.09.
If the WP on the FRAM is disabled, I understand that the network parameters and startup parameters can't be changed.
The WP does not connect to anything, it has a weak pull down internally, so it would appear that just shorting pins 7 & 8 (WP & VDD) would stop the FRAM being updated with the time-on-since-new every 10 seconds, suggesting that there is no need to lift pin 7.
Furthermore, although the I2C SCL line is held low, there is a short period at power up time, about 400ms, when the SCL line is pulled high to VDD with a standard I2C pullup. Both SCL and SDA are open drain high at this point.
By performing a re-write of the time-on-since-new within this 400ms timeframe apparently it is possible to reset the time without disabling the updating of non-volatile parameters
Howardlong:
What are the consequences of disabling updating of the non-volatile memory for the Start-Up Parameters? Does this just mean that we can't - 1. change the SA815's network address from its default, and/or 2. change the Power ON from its Default (vs. the 'Last configuration settings')?
If we don't care about these two things, then would it be Ok to just solder Pin 7 and 8 of the FRAM (U1105) together. or is there something else that could also be affected?
interface ftdi
ftdi_device_desc "ICEbear JTAG adapter"
ftdi_vid_pid 0x0403 0xc140
ftdi_layout_init 0x0028 0x002b
ftdi_layout_signal nTRST -data 0x0010 -oe 0x0010
ftdi_layout_signal nSRST -data 0x0020
adapter_khz 5000
# i.MX28 config file.
# based off of the imx21.cfg file.
reset_config trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
#jtag nTRST and nSRST delay
adapter_nsrst_delay 100
jtag_ntrst_delay 100
if { [info exists CHIPNAME] } {
set _CHIPNAME $CHIPNAME
} else {
set _CHIPNAME imx28
if { [info exists ENDIAN] } {
set _ENDIAN $ENDIAN
} else {
set _ENDIAN little
# Note above there is 1 tap
# The CPU tap
if { [info exists CPUTAPID] } {
set _CPUTAPID $CPUTAPID
} else {
set _CPUTAPID 0x079264f3
jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
# Create the GDB Target.
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME arm926ejs -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm926ejs
arm7_9 dcc_downloads enable
# Section5 ICEBear
# http://section5.ch/icebear
[b]echo "WARNING!"
echo "This file was not tested with real interface, it is based on code in ft2232.c."
echo "Please report your experience with this file to openocd-devel mailing list,"
echo "so it could be marked as working or fixed."[/b]
interface ftdi
# Section5 ICEBear
interface ft2232
ft2232_device_desc "ICEbear JTAG adapter"
ft2232_layout icebear
ft2232_vid_pid 0x0403 0xc140
So could you provide me some help. Do I have the right private key and/or "feature" codes (DSFR, CSAR, ...)? Isn't there a reset possibility to bypass the 12 hour waiting time?
Looks like a new firmware available for the 815:
DSA815: 00.01.12
http://beyondmeasure.rigoltech.com/acton/form/1579/0012:d-0001/1/index.htm
All my license settings (VSWR etc.) were preserved when I updated from 01.09 -> 01.12
Any chance you got a change log with your update?
@mhwlng, did the bootloader version change with this upgrade? Mine is still at 01.03.
