Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 37202114 times)
Original, Gertjan and 2463 Guests are viewing this topic.
Offline ch_scr
« Reply #137200 on: January 23, 2025, 08:07:36 am »
I did notice that it had multiple channels (rear ports) but I imagine these values can only be read over USB/GPIB.  I am looking for multichannel instruments so these ticked all the boxes.  I might also be buying these to satisfy my curiosity in this subject.
At the moment I have no GPIB cables or accessories, and the time investment and money required to prepare all that is a whole other can of worms (I am starting brand new).  Even low baud rate RS232 is sufficient for my needs.  Both USB and RS232 are cheap and fast enough for my use case.  I have some old commodity hardware that I need to make use of, some old servers from the 2000s for data processing and logging.
There is the ADCMT 7352 dual 5 1/2 digit DMM, two independent channels in one box. There's one on ebay for reasonable money from Japan atm. With regard to "hobby grade GPIB2USB" there's the excellent Xyphro UsbGPIB. When re-using old machines, it'll work since they don't have much to do (except e.g. running Linux and a Python script), but running potentially long stretches at a time, these 20Y old machines might not be such a good idea - with their high idle power draw (100W+ if you're unlucky). Better get a NUC (already overkill), smth. based on older Intel Atom is really all that's needed (e.g. DELL WYSE 3040, which will be happy with ~ 5W).
The following users thanked this post: atokhy
Offline atokhy
« Reply #137201 on: January 23, 2025, 06:22:43 pm »
Hello atokhy,
For my requirements, I'll need to simultaneously measure every battery in a DUT and record the performance of the circuit that ends up charging and discharging it (a BMS).  I wonder if such a thing as a multi-multi-meter exists :D (so, a lower precision multimeter that does multiple simultaneous measurements at a lower rate).
Check out the 34970A with suitable multiplexer modules.
Take care when buying : there's an option that cancels/removes the 6 1/2-digit (22-bit) internal DMM.
And of course, you want to keep such a nice feature.
By using an unique 34901A multiplexer module, you can already monitor a 20S battery.
Device is easy to find on the second hand market : ebay (fleebay^^), T&M brookers,...
Thank you, this is exactly what I was looking for!  I was looking at Keithley data acquisition systems but I initially thought these were "master" units that hooked to other measuring devices over GPIB.  I didn't know about this whole "option" system, so I did not understand what they were at first.  Now I know (my newbie is showing)!
There is also the 34972A model which has USB/LAN and webserver access, but they appear to be a lot more expensive ($200 vs $800 used).  After watching a few videos on their use, specifically this video it looks like there are other people out there doing this!
At the moment there are ADCMT 7461A's and ADCMT 7351A's going for auction on Ebay from a US seller and the auction isn't as crowded so I should get better deals here.  These must be from a Japanese manufacturer in the US getting rid of their old test equipment (Toyota maybe). The idle power consumption on the 7461A is pretty low according to my kill-a-watt (about 13W).  This might be the case with the older Advantest R6581E-DC 7 1/2 digit models which I am hesitating on which could act as a calibration source.  The 8 1/2 digit advantest is beyond my budget though if I settle for 7 1/2 as my highest precision multimeter.  Idle power consumption may not be as much of a big deal for me as I have already installed a 9kW solar power system for this house so I should be able to power quite a few toys  >:D.
Offline timeandfrequency
« Reply #137202 on: January 23, 2025, 07:18:26 pm »
Yes the 34972A features more modern interfaces and it's price reflects these improvements.
By using a quality RS232 to USB converter you'll be in business quickly, even with the older 34970A.
These TE are 'all in one' acquisition systems with comprehensive features and they fit to many different use cases. Even with one or two muliplexer modules, you have true versatility.
Free Keysight sotfware to control these acquisition units.
If you want to set up a whole test bench with multiple voltmeters, electronic loads and power supplies, consider using a multi serial PCI card or the old school GPIB bus.
As far as I remember, you can hook 31 devices to a GPIB bus. And many TE from renowed brands feature a GPIB interface. You might also see 'IEEE488' : this is just an alias name for GPIB.
You'll also need :
- USB to GPIB converter
- GPIB cable
« Last Edit: January 23, 2025, 07:29:24 pm by timeandfrequency »
Online Cyclotron
  • *POOF*
« Reply #137203 on: January 23, 2025, 09:15:53 pm »
I've developed a problem even though I mostly lurked in the background. The affliction seems to pass around without engagement.
Oddly, with all this gear, I still turned it all on to ensure I didn't trip a breaker instead of calculating or measuring the load. Obviously, the PSUs can produce far more load if they are active.
I don't do this for a living, but I always wanted to. My skills in IT offer more return on hours spent, though.
I appreciate the community.
I noted my prior post here and did another image from a similar perspective but had to back it up to capture more of my latest affliction. I surprised myself. I didn't realize how sick I'd been.
The red arrows indicate new stuff in the "now" image vs. the "August" image. I failed to point out the entire new workbench on the left.
You can't see the fumes extractor, a couple of Fluke and Agilent hand-helds, lots of hand tools, an entire healing rack to the right, and behind the camera view where projects and items for repair sit in various states waiting for examination or parts.
I've added GPS and Rb 10mhz reference clocks, and there are some other analog meters I am not picturing here.
I think someone needs to take ebay and other options away from me. Much of these items were broken when I bought them and I've repaired them and put them to work. I've actually had to donate a few items to my local high school robotics club to trim the ship.
Now I need a drink.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #137204 on: January 23, 2025, 10:41:32 pm »
The 34972A is a nice bit of kit, worth buying over the 34970A if ypu will be working 'in the field' away from the bench.
The USB function allows you to make programs using the Agilent benchlogger software and load onto a USB stick to insert into the rear USB port to allow for stand-alone automated testing.
I built up a test rig recently for testing individual cell voltages on large 52-cell grid-tie batteries out in the field and it works fantastic, the client has me building another setup at the moment.
These instruments are fun things to play with. :)
On a side note, you can read out the number of relay actuations on the internal relays from the front panel, and the module relays from the front panel or from the PC software. That way you can replace any worn out relays for better test results on second-hand modules.
I found my results were much better and more consistent when I did this, some of the 2nd hand 20-channel modules I picked up had relays were up at 2 million actuations! :D
If you do a before and after ohms test with wire links to short each channel (so you are effectively testing the relay contacts) you'll see much better consistency across multiple runs when you swap out old relays, which is expected.. :)
Also, the 34972A (and maybe the 34970A, not sure) has a CR2032 coin cell inside. A potential source of cheap units with an easy fix if it's throwing errors due to a flat battery. ;)
Just read the service manual and be careful as there are some screws around the DMM module which if removed can apparently potentially affect the calibration. (But you'll need to remove them if you need to replace any of the three internal relays anyway).
Also, replacement VFD displays are available from the usual online marketplaces. Due to the nature of these instruments, they can be left on for long periods during logging, and the red phosphor in the display tends to dim quicker than the green, so a new VFD can be a nice upgrade if the budget allows.
« Last Edit: January 23, 2025, 10:43:51 pm by TERRA Operative »
The following users thanked this post: duckduck, atokhy
Offline atokhy
« Reply #137205 on: January 23, 2025, 11:05:52 pm »
There's also a larger unit, the 34980A (USB/LAN) which is the full rack unit.  The used price for these is about the same as the 34972A (USB) and they come with 40 channel cards, which aren't priced any differently than the 34972A cards on ebay.  I might look into those as well, since unless I'm working on EV batteries, I don't think I'll need more than 40/80 channels (168VDC / 336VDC max respectively).
I see that as the upper limit for my application/use case.
Online Cyclotron
  • *POOF*
« Reply #137206 on: January 24, 2025, 03:40:21 am »
Now I need a drink.
Add the updated photo I missed earlier.
The following users thanked this post: McBryce, salvagedcircuitry, ch_scr
  • Country: jp
« Reply #137207 on: January 24, 2025, 05:56:29 am »
You still have empty floor space and some clear horizontal surfaces.
Buy more gear! :-DD
The following users thanked this post: salvagedcircuitry, Cyclotron
Offline ch_scr
« Reply #137208 on: January 24, 2025, 10:23:53 am »
Now I need a drink.
I spy some ESI device(s) (?) in the upper left corner... Any chance to get a picture of the beautys? Otherwise, yeah TEA tends to fill the available space  :palm:
Online tggzzz
« Reply #137209 on: January 24, 2025, 12:38:58 pm »
That's the point at which your hobby becomes less expensive.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #137210 on: January 24, 2025, 12:41:46 pm »
Eh, no, that's when you start renting more space.
The following users thanked this post: timeandfrequency
Online tggzzz
« Reply #137211 on: January 24, 2025, 12:51:55 pm »
Shut up. Go away. Stop making suggestions like that.
Please :)
Offline Ice-Tea
« Reply #137212 on: January 24, 2025, 01:03:38 pm »
You're right. Renting is stupid. Which is why I'm in the process of buying an additional place.
Offline m k
« Reply #137213 on: January 24, 2025, 01:17:34 pm »
Don't forget foreign opportunities, they are not far and exporting can have local subsidies.
Offline Ice-Tea
« Reply #137214 on: January 24, 2025, 01:21:30 pm »
When you're bored: just let me know. Tons of stuff to sink your teeth in. Pick your poison: RF? Power Supplies? Scopes?
Offline m k
« Reply #137215 on: January 24, 2025, 06:03:37 pm »
Do you have an outlet section, or some other secondary of secondaries part of the store?
Offline McBryce
« Reply #137216 on: January 24, 2025, 07:01:05 pm »
Now I need a drink.
Thanks! Now I can stop looking for the non-existent red arrows in the first post. I was starting to get worried that I either needed glasses or I had started on the sauce a little too early today!
McBryce.
Offline Ice-Tea
« Reply #137217 on: January 25, 2025, 12:26:42 pm »
No. Every once in a while I give up on finding the time for some piece and then I send it off to an eBay auction, starting price 1€ ;-)
Offline m k
  • Country: jp
« Reply #137219 on: January 25, 2025, 03:28:19 pm »
I have no idea... :D
« Reply #137220 on: January 26, 2025, 01:02:24 pm »
OK one for you Vintage HP frequency counter fanboys..
While oup in the attic gatting a HP431 power meter I came across a 5254A 3GHz frequency converter plug-in. It has the mounting frame and mating connector. I think I picked it up like that at a radio rally. condition as-is
IF anyone is interested make me a silly offer. Postage is likely the biggest cost. Located Cambridge UK.
Robert.
Offline factory
« Reply #137221 on: January 26, 2025, 01:44:55 pm »
If no one else is interested can I express an interest in the 5254A?
Also still looking for a set of top & bottom covers for my UK made 5245L, it's the one I rebuilt from scrap. Same for the 5326/7 series, I have a 5327B missing it's covers too.
The covers for the counters in the System I cases differ from other HP TE.
P.S. There was a trashed 5246L on feeBay UK, but someone finally bought it, probably for far more than it's worth with no displays left in it.
« Last Edit: January 26, 2025, 01:46:34 pm by factory »
« Reply #137222 on: January 26, 2025, 03:33:24 pm »
You are top of the list.
Offline ajk1337
« Reply #137223 on: January 27, 2025, 08:16:19 pm »
(Attachment Link)
Robert.
Been looking for this plug-in for my 5245L for a while now. I would like to make an offer. Yes, i specialy made an account to post this.
Offline zepto
« Reply #137224 on: January 28, 2025, 04:42:06 am »
The 7461A is a great choice. It's similar to 34401A/K2000 in specs and environmental characteristics (silent/fanless/sealed), and it's slightly more modern with PC-USB and internal logging/statistics capability. It also allows for 10 second integration, which is highly unusual. It uses a less conventional voltage reference if it's the same as the AD7461A. I think along with USB drivers they provide some kind of spreadsheet with VB/macros to sample directly into Excel, I don't have MS Office license so I haven't tried it. I have used the GPIB interface.
The R6871E is also silent and fanless, but not sealed. It has a bright green LED display that might outlast humanity and real banana plugs, but I'm not sure you are missing out on much. It does have a 1 Gigohm resistance range, 1 MHz ACV, and a usable* extra digit, but it's also quite bulky. They made the R6561 as well, which was optimized for smaller signals/stability/noise and only measured voltage/resistance. The R6581 was the 8.5 digit, I don't have any experience with it. ADCMT might have more modern offerings as well, I'm not familiar with them.
I wouldn't count on finding schematics for any of these, maybe the older Takeda Riken meters they were based on.
Other obscure Japanese meters would be the 6.5d Yokogawa 7561/7562/7563 with bright red LED displays, the more modern 6.5d Yokogawa DM7560, and the 7.5d Hioki DM7275/6.
