I was casually shopping for test gear when Amazon gave me these search results:
What's with the electromagnetic quack products!?
Sub-audible acoustic waves are annoying.
The magic earth wave generators, not the AWGs...
How on earth is 7.8Hz wave, magnetic field, or whatever is supposed to help!? What are the supposed health benefits?
I mean, those things might "work" as advertised, but won't provide the advertised benefits... Maybe you could use one as a degauser?
Its part of the crystal healing "magic frequency" "everything has a natural frequency"
QuoteIts part of the crystal healing "magic frequency" "everything has a natural frequency"As everybody is a different size and shape 1 magic frequency wont fit all,but fear not for a modest fee we can calculate your magic frequency and tune the crystals specifically to your body.For best results due to body changes as you age,we suggest you have your frequency calculated annually and have the crystal re tuned.
Hi all.
Here's some video youtube suggested: https://youtu.be/gYDr-uvl4wc
It's about making electricity from falling rain, based on alleged principle of getting current from water ions. Personally, I don't buy it and suspect the main bias here is the scaling factor¹ but I am no expert in the field. Is this really valid?
Peace to everyone.
¹ I mean this system might not scale well, just like solar friggin' roadways.
Something something "schumann resonance". Its part of the crystal healing "magic frequency" "everything has a natural frequency" and "energy" medcine crap. Its a way for relgious people to try and use science to justify their beliefs, like scientology - but it uses electronics! = science!.
anyone could just ask an AI to explain all these concepts to them
As always it's debatable and depends on our understanding and knowledge base.
For example, the concept of "grounding" or "earthing" is considered quackery by most. However grounding aka charge neutralization and static prevention is a billion dollar industry utilized by electronics, manufacturing, pharmaceutical and food industries. The food industry also uses charged cling wrap creating ozone/reactive oxygen species which are antimicrobial. Also related to research into using electrostatic or plasma-based food preservation, spoilage being a global trillion dollar problem. It's also know the surface charge effects oxidation and the local pH through ion accumulation. This isn’t “magic”, it’s physics and electro chemistry influencing microbial and chemical processes.
A better question is why would anyone be crazy enough to think our external environment wouldn't effect us in some way?.
It's kind of weird that in this day and age anyone could just ask an AI to explain all these concepts to them to get the actual facts of the matter. Why perpetuate ignorance when we could have the entire history of a concept and the science explained to us in minutes?.
Sure there are countless scams out there but in many cases there can be a kernel of truth in it. Ask an AI to explain it to you.
Falling water droplets used to produce charge is a real phenomenon, but not much energy is available. This is at the "energy harvesting" level along with thermal gradients, vibrations, and electromagnetic noise as energy sources. Whether this is a practical method of harvesting microwatts depends on whether it can be implemented as cheaply as those alternative sources.
The supposed snake oil in question is a phenomena called contact electrification aka static electricity known about for a few thousand years or so. The paper can be found here, https://pubs.acs.org/doi/full/10.1021/acscentsci.4c02110
It's funny because I'm an energy consultant specializing in electrostatics and was literally working on this technology this morning.
Who should they get to verify the answer the AI gives them is correct and not made-up slop?
Quoteanyone could just ask an AI to explain all these concepts to themWho should they get to verify the answer the AI gives them is correct and not made-up slop?
C'm'on... we all know AI is reliably unbiased and factually accurate. Right?
Right?
Nvm
This is why people are so afraid and critical of AI imo
Artificial intelligence in its current form is based on the wholesale appropriation of existing culture, and the notion that it is actually intelligent could be actively dangerous
So we can calculate almost anything and compare it to almost anything else in seconds. This is why people are so afraid and critical of AI imo. It gives us facts vs false beliefs and misguided opinions. It also renders some of the most knowledgeable people kind of useless.
QuoteThis is why people are so afraid and critical of AI imo
The reason why they are critical - not afraid - is because AI lies and you don't know when it is doing so. Thus any answer may or may not be correct and since you have no idea if it is, it might as well be not. There are many instances where people have come undone because of this: in law courts it has made up not just cases but references used in those cases, and then presented in court as fact because the user of the AI couldn't be arsed to actually check that it was correct.
https://www.theguardian.com/commentisfree/2023/apr/06/ai-chatgpt-guardian-technology-risks-fake-article
and
https://www.theguardian.com/technology/2023/mar/16/the-stupidity-of-ai-artificial-intelligence-dall-e-chatgptQuoteArtificial intelligence in its current form is based on the wholesale appropriation of existing culture, and the notion that it is actually intelligent could be actively dangerous
Plenty more instances if you're not afraid to look for them. Maybe ask your AI to search?
That's dangerous, and if used in a professional situation without checking the results, could be disastrous. Case in point - here's an example that I have used for training purposes for cautioning junior engineers to not implicitly trust the results of any AI calculations. In this instance Copilot failed to (1) ask if the inputs meant gauge or atmospheric pressure and (2) wasn't 'aware' enough to realize that a gas getting compressed and ending up COLDER than it started violates physics. Part of the problem here is Copilot is not an appropriate LLM to use for solving physics problems, but unlike a human with common sense, it doesn't know its own limitations and proceeds to give a confident sounding wrong answer anyway.
This isn't the thread to discuss AI - its about pseudoscience or techgnology that has no real basis in fact.
There should probably be a seperate sub for AI (is there one already?) but I would say that "trust" in AI is different from "trust" in people and their abilities. THe latter we have lots of data and experience of, so we know how and why people are inaccurate - AI is different, and can give completely wild results - the criticisms are that people put too much faith in AI results without knowing its limitations, and there-in lies the danger. Most LLM are also designed for user experience - they are trained and designed to give the user what they want - and sadly that includes things that the user wants to hear, but simply isn't true.
So I was wrong to say you shouldn't discuss your AI results here - its a great place to post the pseudoscience it can occassionally create.
