Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 1352283 times)
0 Members and 11 Guests are viewing this topic.
Offline Atlan
  • Country: sk
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #1575 on: November 17, 2023, 07:24:29 am »
I want some feedback on the filtering and the other trigger. well thank you
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Firmware is here (or not) https://github.com/Atlan4/Fnirsi1013D/tree/main/Guide%20to%20firmware
Offline pcprogrammer
« Reply #1576 on: November 17, 2023, 08:05:39 am »
The largest part of the trigger handling is done in the FPGA, and it is basically crap. Since it is done on the samples taken it is bound to the sampling rate and won't catch narrow pulses on longer time bases settings.
I did not implement any filtering in my version of the firmware, but if you want to know more about the original firmware filter setup start reading the posts from here on
That is where I found the code they used to do what they do and it is quite inefficient. Spend quite some time on figuring it out and then dumped it and decided to go without filtering first.
Offline Atlan
  • Country: sk
« Reply #1577 on: November 17, 2023, 08:39:13 pm »
The filtering is not very important, too much filtering will create a nice picture that has nothing in common with reality.
The filter is only because the whole design of it is bad.
And also because there is such a possibility.  Worse is the bouncing trigger at higher frequencies or sampling
Offline illiac4
  • Country: si
« Reply #1578 on: November 18, 2023, 05:53:42 am »
I have tried both firmwares and both shows the same behavior. On original when I do the test measure  on the back of the oscilloscope the 1khz option the wave is shown. Also there is a clear view of the screen.
On both non original firmwares only one tiny violet line is shown when 1khz test is connected. And screen shows on the yellow tumbs brighter horizontal spots.
Offline Atlan
  • Country: sk
« Reply #1579 on: November 18, 2023, 08:18:02 pm »
Please pictures, thank
Offline illiac4
  • Country: si
« Reply #1580 on: November 19, 2023, 04:40:30 am »
Here they are.
Offline Atlan
  • Country: sk
« Reply #1581 on: November 19, 2023, 04:47:16 am »
Turn OFF mode X-Y ;)
« Last Edit: November 22, 2023, 04:23:51 pm by Atlan »
Offline illiac4
  • Country: si
« Reply #1582 on: November 19, 2023, 05:21:18 am »
Oh. TNX. What about the colors of the screen?
Offline Atlan
  • Country: sk
« Reply #1583 on: November 19, 2023, 05:55:43 am »
fix in firmware 0.019g
This is a question for the flood programmer. I can see a yellow wavefrom on yellow background.
1. Edit Trigger for higher frequencies, and cancel the correction I gave there.
2. 50% TRIGGER to change to calculate it to set it real to 50%
3. Off Move (Tracks) If the channel is turned off.
4. Switching the Sampling Frequency-Repair at WaveFrom Thumbnail
RMS I still didn't look around.
« Last Edit: January 07, 2024, 04:30:38 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #1584 on: November 19, 2023, 10:05:57 am »
I started work to integrate RTC DS3231. It will be contributed as a Case and Date Setting menu. And find out if this information can be written to the file. This will require extensive code adjustments. Hardware should not be a problem. Fit 4 wires for large area of 0805 components.
It would not be able to change the file name by date-time and omit the change of file attributes, what do you ?
I will remove the errors described by the bug. Soon a new firmware - modified trigger. I hope it will be good.
« Last Edit: November 19, 2023, 12:38:12 pm by Atlan »
The following users thanked this post: illiac4
Offline Atlan
  • Country: sk
« Reply #1585 on: November 21, 2023, 10:07:44 am »
Can someone explain to me the reason why they did not use an analog trigger with a comparator?
« Reply #1586 on: November 21, 2023, 10:26:45 am »
Who knows? Money, incompetence, inexperience, etc.
Offline Atlan
  • Country: sk
« Reply #1587 on: November 21, 2023, 12:04:07 pm »
It is possible when they didn't even give the RTC for 1E.  I have the feeling that they designed it in the simulator and then had it manufactured.  Without any tests.
The whole design looks like it was made by students.
Offline Atlan
  • Country: sk
« Reply #1588 on: November 21, 2023, 08:34:19 pm »
So if you have time to have fun. the color of the H trigger varies depending on whether the trigger trigger value is found in the samples. red trigger not found - the middle of the buffer of samples is used. green trigger value found (+- 2 bits)
To give you an idea of how "well" a digital trigger based on an AD converter works.
I think there's no point in looking for the trigger value in the samples. in the case of a rectangular course, there is nowhere. you just have to think that it is always in the middle of the sample.
« Last Edit: November 21, 2023, 08:39:13 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #1589 on: November 22, 2023, 11:22:28 am »
Version for use: v0.015
Trigger location, fixed in the center of the sample. (real center-4)
« Last Edit: November 23, 2023, 01:20:29 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #1590 on: November 22, 2023, 04:21:01 pm »
So adding RTC to use the file name in date and time format, maybe I will also leave the serial number.
Is anyone thinking about installing the RTC there?
Even if I don't announce, I constantly remove errors found.  And I added a couple of them too :D
« Last Edit: November 22, 2023, 05:53:40 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #1591 on: November 23, 2023, 01:23:46 pm »
I see 15 downloads the last version. Is there a trigger better? Signal less jumps up down?
Offline Alex62
  • Country: ru
« Reply #1592 on: November 23, 2023, 06:50:24 pm »
Yes. Up down got better. What can not be said about the horizontal, especially less than 100ns.
Thanks for the work.
Offline Atlan
  • Country: sk
« Reply #1593 on: November 23, 2023, 07:51:47 pm »
Triangle square  sine? Triger 50%? One or 2 period on displej. Pls upload video.
Do you have a lipo to 5V converter installed?  The used linear stabilizer requires a minimum input voltage of 4.3V.  (good idea to power it from a 4.2V battery that is discharging)
« Last Edit: November 23, 2023, 08:41:57 pm by Atlan »
Offline Alex62
  • Country: ru
« Reply #1594 on: November 25, 2023, 06:53:36 pm »
Video without DC-DC at 5 volts.
I put DC-DC on 5 volts - only the interference increased.
Offline Atlan
  • Country: sk
« Reply #1595 on: November 26, 2023, 06:29:15 am »
So you have to write it in FNIRSI, because if the captured sample contains the numbers 78,82,77,81 and the trigger is set to 80, it is difficult to find out where the trigger is. That's how a digital trigger works.
Maybe after collecting 10 samples and averaging them, I believe that the signal will be clean, but unrealistic.
The AD converter picks up interference and this has a big impact on the result.
Offline Atlan
  • Country: sk
« Reply #1596 on: December 03, 2023, 07:13:01 am »
So the files already have a time and date stamp.
1943433-0
It is worse with the display of date and time in the thumbnail oscilloscope, the flood programmer took it quite comprehensively and included the path to the file in the name.  Which complicates things quite a bit.
1943475-1
« Last Edit: December 03, 2023, 09:27:03 am by Atlan »
Offline Atlan
  • Country: sk
« Reply #1597 on: December 03, 2023, 01:36:23 pm »
Fixed error, channel 1 axis could not be moved after autoset, If channel 2 is off.
« Last Edit: December 04, 2023, 01:15:48 pm by Atlan »
Offline Atlan
  • Country: sk
« Reply #1598 on: December 05, 2023, 09:20:42 am »
Assembly of the RTC module.
It is necessary to program the menu to set the time and date.
Offline Atlan
  • Country: sk
« Reply #1599 on: December 05, 2023, 05:37:14 pm »
There would be interest in modified oscilloscope software for fault finding on underground cables.?
