Author Topic: Test Equipment Anonymous (TEA) group therapy thread  (Read 36929692 times)
Robert763 and 5435 Guests are viewing this topic.
Offline vk6zgo
« Reply #133000 on: February 14, 2023, 12:57:12 am »
The Taiko Denki Connectors are also a pain in the butt.
Kinda the same type of cheap connector
Thanks for that, Wallace.
I was trying to remember what they were called!
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #133001 on: February 14, 2023, 05:30:53 pm »
Hmmm, so. I want to start messing with doing some semi-auto calibrations with the TDS scopes, but I need two GPIB cards.
Now, I have two National Instruments GPIB-PCII/IIA cards, but one is faulty...  :(
there's like only 5 chips on the thing, and I just pulled one out and tested it in my retro chip tester, but it tests good.
Maybe I'll swap chips between my good one and cross my fingers the busted chip isn't unobtanium.......
The following users thanked this post: Vince, Specmaster, ch_scr
Offline Vince
« Reply #133002 on: February 14, 2023, 06:30:51 pm »
Oh, your TDS addiction is getting fancier by the day, I like that ! >:D
Good luck with fixing that second board, may the force be with you !
Interesting....keep us posted....
Offline m k
« Reply #133003 on: February 14, 2023, 07:10:27 pm »
Other try with protoboards.
Target is 1mm or less thick single side or 1.6mm thick double side board.
Edge must have 0.15" spaced contacts.
If I search just FR1 protoboards I'll get plenty of good looking results.
Edges are not defined but some 12x18cm boards are very close.
Then looking closer, what is prototype paper PCB fr4 or single side copper pcb.
How on earth it is so difficult to do things even closely as they should.
I bought few with unknown properties but quite small edge contacts are clearly 0.15" spaced, or so is stating the picture.
Offline extremgear
« Reply #133004 on: February 14, 2023, 07:21:26 pm »
Hello,
Some news of my 3457A acquired last week.
i found U403 ( analog switch intersil HI-390) nearly dead on the input signal conditioning side hence the hardware 64 error, only the 1 AMP range work the other range doesn't work ( Ma,Ua ) : when other range than Amps range are selected U403 send 5V straight to U101 (hybrid module) i came to the conclusion that this circuit is dead, furthermore when testing on breadboard IC was behaving weirdly on one of the 2 switch only.
i will order the circuit and give some news .
My big concern with this meter is the lack of screws to close the upper cover , i'm not able to find a reference of this screw, my plan is to machine screws from existing screw , but i'm not able to find the size ( thread pitch and length ) maybe somebody have i idea ?
Huge thanks !
The following users thanked this post: ch_scr, factory, duckduck
Online factory
« Reply #133005 on: February 14, 2023, 07:26:14 pm »
I'm sure someone on here will have one to measure, I couldn't tell you if they were imperial UNC as used on older HP, or Metric that were used for later HP.  :-//
I've bought UNC screws from both ACCU in the UK and Amazon in the US.
« Last Edit: February 14, 2023, 07:31:18 pm by factory »
Offline duckduck
  • 20Hz < fun < 20kHz, and RF is Really Fun
« Reply #133006 on: February 14, 2023, 08:19:04 pm »
Speaking of HP multimeters...
One of you TEA nerds will know this ;) I've got an HP 34401A with Revision code of 05-01-01. The most recent date code I found in this unit was 1995. It looks like VFDs are widely available for the 34401A again now. Were there different revisions for the VFDs that I need to be aware of, or just order one and replace it?
Also, are the new ones replacement VFDs pretty bright? My VFD is not really dim, but it certainly doesn't pop the way that I want it to. I only paid ~USD66 (plus a cheap repair) for it, so a new VFD for ~USD50 is not a crazy investment.
EDIT:
Ended up buying this one off of AliExpress for USD37 (delivered). I'll let everyone know how it works out.
https://www.aliexpress.us/item/3256803185081674.html
« Last Edit: February 16, 2023, 06:58:09 pm by duckduck »
The following users thanked this post: BU508A, factory, m k, extremgear
Offline extremgear
« Reply #133007 on: February 14, 2023, 08:36:53 pm »
i just figured out that the screws turned out to be usual M4 ( metric) thread !
very good deal !
Offline timeandfrequency
« Reply #133008 on: February 14, 2023, 09:05:34 pm »
Hi extremgear,
it's not the best solution to machine a new thread on an existing screw.
You'll find some Imperial screws here.
« Last Edit: February 14, 2023, 09:07:43 pm by timeandfrequency »
The following users thanked this post: extremgear
« Reply #133009 on: February 15, 2023, 01:21:57 am »
Sharing this useful tip for dealing with cleaning of sealed or inaccessible pots.
https://teanonymous.com/f1/viewtopic.php?t=109
The following users thanked this post: BU508A, Specmaster, Mortymore, Neomys Sapiens, wolfy007, ch_scr, duckduck, m k, extremgear
Online AVGresponding
« Reply #133010 on: February 15, 2023, 06:32:36 am »
As long as it's just a faded VFD those are easy enough to replace, and they are all the same; the unobtainium driver ICs for the early units are a different matter. Not sure where the exact changeover happened, but generally people speak of the banana sockets being all red indicates an early version. The symptoms for those failing are (afaik) segment bleed-over/ghosting.
Regardless, $66 is a fantastic price, congrats!
The following users thanked this post: Specmaster, duckduck
Offline wolfy007
« Reply #133011 on: February 15, 2023, 02:29:02 pm »
Went to see a guy advertising an old Compaq LCD monitor that I wanted to grab, upon entering his garage to grab it I saw a couple pieces of test equipment. Look interesting offered him AU$120 (what was left in my pocket) and he agreed.
Now I just need a service manual if any one knows of one. I was only able to find a user manual for a COM-120B.
The following users thanked this post: Ice-Tea, TERRA Operative, duckduck, m k
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #133012 on: February 15, 2023, 02:32:26 pm »
I made a mistake. I updated Altium. Swore to never do that again. And yet, here we are.
  • Country: jp
« Reply #133013 on: February 15, 2023, 03:34:36 pm »
Well, boooo.
Seems the main chip on my second National Instruments GPIB-PCII/IIA card is the bad one, the one I was hoping for it not to be.  :(
So, unless I can source a NAT4882D chip, this card is dead.
Also, it seems my fancy Dual CPU Dell Precision workstation only has one ISA slot, but my Dell Dimension V400c has two, so I might have to do a switcharoo to get two GPIB cards running.
BUT, the Dimension has no AGP port, so no Quadro GPU for other fun... booo again.
I might get on the hunt for a different motherboard and case, see if I can find a decent motherboard with AGP and two ISA slots.
And another NI ISA GPIB card..
Offline duckduck
« Reply #133014 on: February 15, 2023, 05:02:28 pm »
I would contact IFR: https://rfimagingandcommunications.com/support/
EDIT:
Looks like a nice little SA for RF work?
« Last Edit: February 15, 2023, 05:15:23 pm by duckduck »
Offline Ice-Tea
« Reply #133015 on: February 15, 2023, 05:07:47 pm »
Huh. Didn't see that coming.
Working on a HP 334A. Needed a sig gen and since that recently acquired Sigilent was around I grabbed that. Seems to work fine and yes its updated. Actually, the rotary is shit and some of the buttons have problems but I won't hold that against them as it has been with a smoker for quite some time.
What I DO hold against it is what happens next. Starting out with the simplest measurement, just use it as voltmeter. So, the 334A reads well over a volt when I feed it a 1V signal. So, I figure, well, old gear. Unfortunate, but it's somewhat expected it would drift over time.
Just for fun and giggles I figured to double check.
Well, screw you.
EDIT: well, don't send a boy to do a mans job, eh?
« Last Edit: February 15, 2023, 05:44:46 pm by Ice-Tea »
The following users thanked this post: Peter_O
Offline DC1MC
« Last Edit: February 15, 2023, 05:37:54 pm by DC1MC »
« Reply #133017 on: February 15, 2023, 05:45:27 pm »
Is this thing worth 300€ ?
https://i.ebayimg.com/images/g/6BAAAOSwIVpj6piN/s-l1600.jpg
eBay auction: #185775926003
Yeah, I'd say it's about the right price. It's 200MHz, 4-channel, and 2Gsa/s so meets the 2.5x Nyquist limit with all 4 running, it has all the bits with it, and is probably hackable to a higher bandwidth.
You could always try a cheeky message to the seller offering a bit less...
Online factory
« Reply #133018 on: February 15, 2023, 05:50:04 pm »
One Two for this page....
First power up on arrival.
This fault was very easy to fix.
« Last Edit: February 15, 2023, 05:54:49 pm by factory »
The following users thanked this post: Vince, doktor pyta, ch_scr, TERRA Operative, cyclin_al, AVGresponding, duckduck, m k, Peter_O
Offline Vince
« Reply #133019 on: February 15, 2023, 07:47:39 pm »
Well, boooo.
I apologize in advance for my dumb question but... I don't understand you need TWO of these cards ?
The Tek calibration S/W requires it, because it's a PITA, OK... but why can't use just any other GPIB adapter for the second link ?
Non genuine ISA, or genuine PCI? or non-genuine PCI, or USB adapter, or just... well, any GPIB adapter you might fancy ?
Offline tautech
Avid Rabid Hobbyist
Offline tautech
« Reply #133021 on: February 15, 2023, 07:54:53 pm »
Well, screw you.
To which version ?
Apparently with old HW versions the self adjust feature disappears with the latest FW.  :-//
Install nothing later than V1.08.01.15 for now until we get on top of this.
Avid Rabid Hobbyist
  • Country: jp
« Reply #133022 on: February 15, 2023, 11:30:48 pm »
Well, boooo.
Because old DOS software is inflexible and hard coded to use one type of card... also, USB wasn't a thing back then, and I doubt there are even USB drivers for DOS, let alone something the Tek software will recognise....
The software lacks any form of GPIB card config settings as it just assumes you will use the Tek supplied or recommended GPIB card.
An NI TNT GPIB card might be close enough to work, but for the cost of getting one of those.... if it doesn't work I'll have to buy the PCII/PCIIA card anyway, so I may as well just stick to buying the PCII/PCIIA card.
I just wish ebay shipping costs didn't suck so much from overseas....
Offline hvontres
« Reply #133023 on: February 16, 2023, 06:09:47 am »
Well, boooo.
I use an old HP KYAK XW, with dual PIII's. It has 1x AGP, 3x PCI, 1x ISA and 1 ISA/PCI slot. I also have a TNT GPIB, but I am pretty sure that the TEK software can't see that card. I'll toss it in and see what happens.
Henry von Tresckow
I am not an EE, but I play one in the Garage
Offline Ice-Tea
« Reply #133024 on: February 16, 2023, 06:31:06 am »
Well, screw you.
To which version ?
I thought the latest... But apparently, according to my download historySDG800_1.08.01.13R6_EN? Not the latest then. Not sure why not. I'll have to figure that out when back in the lab. :-//
