i install a008 just now,but my device still show (a007)00.01.01.sp1
How does the “Settings” button appear under the Start menu?
’“Android setting”
it‘s’“Android setting”
Your software "Sparrow_mod" can add this function, that is, in addition to adding "DHO800" when the screenshot, add the date and time, like this
((Tried to connect DHO804 via WiFi. May someone use wireless connection and can tell should it be so bad?
With such lags Webcontol become almost unusable.((
LAN connection works flawlessly.
Attaching a ping window screenshot.
Tested using ping command from Windows command prompt:
ping -t xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx - scope IP address
This is a proof of concept of an editable button panel, the configuration file will be a simple text file in JSON format stored in the user storage space, the panel can have many buttons, it is scrollable and currently supports chained SCPI commands and launching applications.
where xxx.xxx.xxx.xxx - scope IP addressI have this on WiFi. On a wired connection, a stable 1 ms.
looks the best, but it will not enough space for label in 1 row.Cache file in dalvik-cache not exists.
It's failed to re-mount system partition as read-only after installing services.jar
Some optimization is seems to tight for me - measurements font in compact view is too small - in details view it's ok and readable.
Could you please make it the same size as details or higher. DVMlooks the best, but it will not enough space for label in 1 row.
Ideally, selectable font size
Unfortunately, horizontally splitted windows sill waisting to much on window headers. Is it possible to hide window header? Similar to status bar.
In multi-window mode vertical axis scale become too tight, not readable. Is it possible to hide half of it?
Hi guys i have a question. How can i clone the sd card from dho800?I like to have one buck up for safety.I run google search and i can"t found the right page on the eev forum.Thanks for any help.
. I counted 39 pixels (vertical pinks lines), and then for comparision, i drew a rectangular with the same height. So by removing those borders, the waveform view could be made significantly bigger, or two lines of information could be displayed on the whole width of the screen. Of course you could do a combination of those.I see two custom firmwares (GUI at least). I think it would be a good idea to combine the efforts.
What will be extremely useful, is probe multiplier from keyboard, like 11.5x. Sometimes there is a need to make temporary probe and there is no good choice of resistors. Sometimes other reasons.
What will be extremely useful, is probe multiplier from keyboard, like 11.5x. Sometimes there is a need to make temporary probe and there is no good choice of resistors. Sometimes other reasons.I'll be happy to be proven wrong, but it seems like the multipliers are hard-defined in the .so library, and so implementing this may be unfeasible.
