(Covid quarantine)
Did you say that it also happens also in ºC mode?
ill go over the stlink tomm and touch up all the pins and things and try again. either way i have two more coming that are supposed to be better quality we shall see
Works in F now, good job. (I should use C, but 50 years of habit )
It did not happen in C mode. I will test it more tomorrow, but right now it works OK.
Thank you.
Thank you for your updating, i really appreciate your work with this firmware.
But on new update I found a problem about the screen on SW: r7b29f04, HW: KSGER30F101.
When turn on with "No Iron" the screen just display for 5 seconds and turn off (just screen off) then i plugged the iron in, the board know and heat it but the screen still off. This prolem is same to sleep mode, shake to wake but screen no wake up.
There is the video demonstration: https://youtu.be/9cyWZL-GL-4
I recommend you erase the mcu and flash it again after that.
Try the attached FW. I removed that specific command.
It must be something with that display. Other v3.0 KSGERs don't have the issue.
I think you didn't understand. I mean that while in the settings and adjusting the brightness, does the screen dim until the minimum brightness? From 255 to 5 it's always on but less bright?
How did you do with the previous fw? Did you build yourself?
Download the st-link utility, erase the mcu, open the bin file and program it.
Nice! Are the calibration results consistent every time?
Those values seems pretty high, since the KSGER have lower amp gain than Quicko... I don't remember having such high values.
Keep an eye at it, maybe the sensor is "unripe" and reports different values, it might drift with the use.
It would be interesting to check the sensor output variation after some burning time.
I remember Jesus having calibration of 1700 @ 400ºC. My last calibration was 3100.
I'm currently without iron tips, I hope they arrive in 1-2 weeks, for now I can't test anything.
200/1461
300/2176
400/3013
200/1388
300/2046
400/2626
200/1390
300/2043
400/2640
OK, using current code (r7b29f04), I did full reset, then calibrated 3 different tips:Code: [Select]200/1461
300/2176
400/3013
200/1388
300/2046
400/2626
200/1390
300/2043
400/2640
Thank you! Yes i built fw myself. Didn't know what to do with .bin file now i get it. Problem is solved.
just flashed the newest firmware, the problem remains. the ksger firmware tip is working fine.
