That microbolometer still looks hotter than I would have expected but interestingly there is no evidence of a hot spot on the rear of the PCB under the microbolometer.
It will be very interesting to hear SEEKs thoughts on this matter, hopefully tomorrow.
Aurora
After being on for a while and the shutter forced open if I force it close, the image is less even but not terrible:
The shutter arm may also conduct away heat from that part of the flag.
New app version was released on the 24th:
https://play.google.com/store/apps/details?id=com.tyriansystems.SeekThermal
What's new:
* Corrected crashing issues on various devices.
* Image quality improvements.
* Other misc. Improvements.
Can someone confirm if it has a firmware upgrade?
Image has new firmware built Oct 21.
#if AVERAGE
int[] deadpixelarray = { 10, 6, 2, 13, 9, 5, 1, 12, 8, 4, 0, 11, 7, 3, 14 };
int deadpixel;
ulong average;
ulong numpoints;
int v;
for (y = 0; y < 156; y++)
deadpixel = deadpixelarray[y % 15];
for (int x = 0; x < 208; x++)
if (x == deadpixel)
average = 0UL;
numpoints = 0;
if (x > 0)
average += data.PixelData[c - 1];
numpoints++;
if (x < 208)
average += data.PixelData[c + 1];
numpoints++;
if (y > 0)
average += data.PixelData[c - 208];
numpoints++;
if (y < 155)
average += data.PixelData[c + 208];
numpoints++;
if (numpoints > 0)
average = average / numpoints;
else
average = data.MinValue;
v = (int)average;
deadpixel += 15;
else
v = data.PixelData[c];
v = (v - data.MinValue) * 255 / (data.MaxValue - data.MinValue);
if (v < 0) v = 0;
if (v > 255) v = 255;
bmp.SetPixel(x, y, Color.FromArgb(v, v, v));
c++;
#else
int v = data.PixelData[c++];
if (v < 0) v = 0;
#endif
Edit: got rid off an unused variable and defaulted the dead pixel to min value instead of max value if it couldn't average (but that should never happen anyways)https://github.com/sgstair/winusbdotnet
I still have some plans to improve it, at the moment it's just doing very dumb calibration on the raw data and rendering it.
What's new:
if (bmpQueue.Count > 3) bmpQueue.Dequeue();
it was > 5 //get image
Bitmap sourceImg = new Bitmap(@"C:\temp\thermo\seek.png");
Color leftPixel, centerPixel, rightPixel, topPixel, bottomPixel;
int avgVal;
//loop trough horiz pixels
for (int x = 0; x < sourceImg.Width-2; x++)
for (int y = 0; y < sourceImg.Height-2; y++)
leftPixel = sourceImg.GetPixel(x, y + 1);
rightPixel = sourceImg.GetPixel(x + 2, y + 1);
topPixel = sourceImg.GetPixel(x + 1, y);
bottomPixel = sourceImg.GetPixel(x + 1, y + 2);
centerPixel = sourceImg.GetPixel(x + 1, y + 1);
avgVal = (leftPixel.R + rightPixel.R + topPixel.R + bottomPixel.R) / 4;
if (Math.Abs(leftPixel.R - centerPixel.R) > 20) //if pixel is too different use average color from near pixels
sourceImg.SetPixel(x + 1, y + 1, Color.FromArgb(avgVal, avgVal, avgVal));
sourceImg.Save(Application.StartupPath + "\\clear.png");
