CAN is differential, so there is no different information on Can-Lo and CAN-Hi.
Thanks. Perhaps these are bugs. I will report them in the specialized bugs thread, although I’m not sure if anyone from Siglent reads those posts or actually cares.Oh, boy! This scope gives me a lot of headache! In addition to the previous questions posted here, which are still not clear to me:what am I doing wrong this time?
- https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg3551527/#msg3551527
- https://www.eevblog.com/forum/testgear/siglent-sds2000x-plus-coming/msg3551491/#msg3551491
I am trying to set up the user-adjustable rise-time and fall-time measurements. It works okay with percentage values. But I cannot make them work with absolute values for C1, C3, etc.: that is, for any values that I select for Horizontal parameters I get an "Invalid threshold" error message. But they seem to be working perfectly okay for the Math channels, e.g F1 (which is the sum of C1+C3). See screenshots attached.
I even calculated the absolute values to match the percentage values, and the absolute measurement setting still does not work for the C channels. What am I doing wrong here?
Thanks a lot!I am getting the same errors
Well, I think it´s time to "clean up" the bug thread, when the new firmware comes up.
I currently have vacation for 3 weeks, I´ll start with it at the forthcomung weekend.
Just browsed through the release notes of a beta version of the next firmware.
Most if not all of what has been discussed in the last few months seems to have been addressed.
Where can I find this information?
Would be interesting to read what's coming up next :-)
You can't... Tautech has some info from beta test proces.. He already said all he can..
What can I say, he's a tease....
More teasing....
~35 changes coming plus a few further requests added since the beta FW was put in front of beta testers.
I can say it will be well worth the wait and not just for the fixes but also the new features added.
New Siglent option bundle promotion:
For all sales areas except NA unfortunately.
Expires Sept 30 2021
With new purchases of SDS2000X Plus DSO's:
MSO SPL2016 HW with license and 50 MHz AWG/FG license for just $ 219 !
https://int.siglent.com/info/detail-49.html
On the page for that link it says, "This promotion is only applicable to the European and AAAS region". What is AAAS region? Does the new purchase need to be made within the promotion period? I bought mine last month, would that qualify?
For a limited time, all new SDS2000X Plus purchases can get an option bundle for only €199. This bundle includes the SPL2016 and MSO and function generator activation licenses.
1. The SDS2000X Plus series oscilloscopes must be purchased from an authorized SIGLENT distributor.
5. All Offers are valid from August 2nd , 2021 to September 30th, 2021.
I´ve meant it in general, what we´ve noticed so far in this thread, what was solved from siglent, what´s still to do and so on...
Since today I have may a new one using current FW... (did not search on this lengthy thread)
1. running on 8 bit, vector display mode, on CH1 a digital square wave (0.3 low to 3V high) as 10MHz with 0.5ns rise/falling time
2. trigger about the half of the wave, show with cursor some 20% to 80% rise time as 0.5ns
3. add also color mode
4. all looks fine so far showing about 2 waves, with some small overshoots
than as soon I
5. enable Ch2, with or without 50E input, as nothing to display just enabled
6. On Ch1, the edges and overshoots gets modulated as like 50Hz, changed square from 10MHz to 49Mhz with same behavior
7. Change than from vector to pixel mode
8. all looks than fine .... No any more edge modulations visible
is this known?
IMHO it would be nice to have a thread moderated with current so easier to track as a bug tracking system
is this known?
than as soon I
is this known?
How about if you enable CH1 and CH3 ?
Yeah ...
gear needs replaced by professional stuff as it goes with SSA 200Hz Span & 1Hz BW and synthesizer jitter (also wobbling)
