Calling @Frex to post screenshots of the Sys Info page of the unit we helped to recover.
This info can be helpful to Siglent to find where the update issue is.
Previous FW version too if remembered.
TIA
A screenshot of sysinfo of my "recovered" SDS2104X-Plus.
(Thanks to Tautech
Regards.
Frex
In XY mode the timebase doesn't matter, because the scope is not plotting voltage*time, but voltage*voltage
i've found that timebase does matter, at least on all my oscilloscopes, because the XY plotter will plot everything currently in memory, too fast a timebase compared to the input signals and you only get choppy bits of the whole picture, too slow a timebase, and if the picture changes too quickly, you get the full picture, plus remnants from the previous "frame", plus all the "connecting lines"
Interesting. However, it sounds like you're describing my experience with adjusting the memory depth. It's likely the timebase's effect on the memory depth that you're seeing affect XY mode.
i do this mostly with the analog discovery 2, with 8k points, and have found timebase matters even if memory stays the same. when i did this on my keysight which has no way to adjust memory depth, i also found timebase mattered, especially since to get a good image i had to use the high resolution mode, which gets weird at the faster timebases, sometimes seeing just a bunch of thick blurry points if too fast, or chunks of the image if too slow, the keysight is dead now, so i can't see this new song on that one, sadly.
I'll try it out and see what happens with my Siglent.
The main issue with DSOs and XY plots is actually "blind time". For an analog CRO without cursors or indicators there should be no blind time, but on a DSO blind time can exceed 99%. Blind time can be calculated if you know the timebase and refresh rate (waveforms per second). Reducing the memory depth decreases the processing time and increases your waveform rate. For rapidly changing XY patterns like your music test, small memory and short timebases with a high waveform rate may look the best even though the signal is actually getting chopped up into small segments. There's an ideal setting for this that gives you a very high waveform rate (as in actually almost meets the advertised spec) but I don't recall that setting at the moment.
That was my assumption regarding the timebase adjustments. I just tested it out, and the waveform rate around 2 - 5MSa/s seems to be the best performance for that music. Going too high on the timebase made it both slow down and reduce the waveform proportions on screen. That's with 10kpts set as max mem depth.
Here's a slightly extreme comparison for refresh/mem depth. At 1Gs/s, the image is squished. I wonder what the intended rate is from the music.
Shameless plug to my attempt with the HD
https://www.eevblog.com/forum/testgear/siglent-sds2000x-hd-12bit-(published-for-chinese-domestic-market-only)/msg5446511/#msg5446511Scope settings:
Input settings (CH1, CH2) : 50-ohm termination, DC coupled, 20M BW limit
Timebase : 1 ms/div, 1 MSa/s, 10 kpts memory
Trigger : Normal, alternating edge, CH1, AC coupled, 0V offset
Using the high quality .WAV file, playing it back at high bit-rate and resolution makes a huge difference. Interested to see if that increases quality on the Plus as well.
I bought a copy of OsciStudio to test this out, and eventually make a very stupid video.
In the meantime, it was useful to test both refresh rates and audio frequency effect on the XY results:
The first section is more obvious, that's scrolling through refresh rates (first 50 seconds). The last 30 seconds is screwing around with the frequency of the shape. Chris's tutorial shows him using A1 at 55Hz, which is (one of the reasons) why my results aren't as great with his music. A4 at 440Hz (and really most notes over ~100Hz) show much greater stability on my scope.
Scope settings:
Your settings are pretty close to where I landed after my test video. However, the default edge trigger and your trigger settings didn't appear to make any perceivable (to me) difference, neither did changing coupling.
I will make another video to see if I can get better results than my previous attempt.
Thanks,
Josh
I did some tests to see if anything made any significant impact in quality. The short answer: nope. The HD model has better hardware, and the results show it. At least that's my uneducated guess. 😉
I tried all sorts of things including running my audio card at 44.1kHz to 192kHz (with the wav file loaded in Studio One to match the output settings).
I also tried using some mp4 files that came with the software purchase (not sure if they're available free), and that let me tweak some settings. Unfortunately, the result was I couldn't get a happy medium between memory depth and refresh rate to reduce flickering, or maintain enough of the image. It still looked pretty good, but is just another thing (that doesn't matter) that makes me want an HD scope.
