Thanks for the reply....
You want just simple stable triggering right ?
Hit Stop and eyeball the longest packet duration and in the Trigger menu set Holdoff to a slightly longer duration.Yeah, that's kind of other way to get it work but I'm curious why it is not working with the zone settings method.
I wanted to know if it is (potentially) a bug, or I'm just using it wrong way.
Zone Trigger is not actually a trigger, but an additional filter for the well known existing trigger modes. A filter that looks at the regular triggered records and neglects all those which don't meet the zone trigger criteria.
What does this mean for single shot capture? You only capture one single record and chances that this one meets the zone criteria are very slim indeed.
Interestingly, seems the newest firmware(V1.5.2R1) also introduced a new bug! (see the screenshot and you'll find somethings missing lol)
Can look at it tomorrow on our scopes.
Thanks tubularnut but hiding menus in screenshots is tucked away in another menu.
Real curse without a unit here to show everyone.
It impacted on both Save/Recall saves and Print saves.....but maybe it's only in the higher end models yet.
Depending the frequency of the AWG (and so the time to chek the zones of trig (?)), the single trigger failed by me too. At 1Khz all is fine, at 250Khz it's no more the case.
(Attachment Link)
You mean this one? Under Utility - Save/Recall
Mine was turned off (by default? I've never used it before)
(Attachment Link)
Unzip and import resulting csv file into the scope internal AWG. AWG settings were: 100kHz freq, 2Vpp amplitude, 0v offset
(Attachment Link)
I'm glad to meet a Korean.
I tried generate the attached file waveform.
I think it's because the waveform update rate is fast.
If you slow time the holdoff or use a slow waveform update rate scope, it will appear as a single waveform.
You look at a fast scope like a keysight, it's normal to look like an eye patterns.
https://drive.google.com/file/d/1btd4aXcO6Wxs7neXFRpmnoKH9guG6mQX/view?usp=sharing
At work I´ve updated one 2K+, the others not so I can compare the menus old/new fw to see whats new/changing(without a notice)...
Here the "true changes":
Yes all described as: Optimized UI
Only the SDS2000X HD is missing the new Mem management feature added to the other models.
Only the SDS2000X Plus is missing the new Mem management feature added to the other models.
Only the SDS2000X Plus is missing the new Mem management feature added to the other models.Any news, if the Mem management feature will ever be added to SDS2000X+ Series ?
