I've got smoke absorber unit today for my homelab. A long overdue piece of gear. I don't solder that much at home, but still, it's cheaper to pay once for the absorber, than pay later to doctors...
That looks awesome - but with a cat that's always in the lab, that thing would be clogged in about a week!
Pat, great haul! Love the old HP, does that have the light bulb the freq control circuit?
Rob
Ain't that cheap, bit over 700$usd.
Protip: use the cat as a filter.
200-Watt 220/240V to 110/120V AC Step Down Transformer
I intend to power a 60W embroidery machine with it
I wonder how trustworthy those things are, aiui they are designed for light duty devices like shavers.
I prefer to use these step down transformers to power my American gear, they run for years perfectly and are built like tanks in a full metal case.
https://www.jaycar.com.au/120w-240-120v-isolated-stepdown-transformer/p/MF1080
Metcal MX talon system w. 5 tips , a stand (Thanx Kev) & a MX500P PSU
Nice addition to my existing system
/Bingo
20161214 edit to add 2nd pic - a few more bits and pieces recently, for a future larger 3D printer (sort of) project.
Not exactly a purchase, but more like an exchange.
I've gave my Weller WD1 + WSP80 iron, in exchange to this Data Precision 8200.
The picture is just a rapid turn-on, to check things up (i've used my most recent cal multmeter), 2 digits less than the calibrator.
I've gave my Weller WD1 + WSP80 iron, in exchange to this Data Precision 8200.Nice trade. i always wondered how those newer Wellers are.
I've gave my Weller WD1 + WSP80 iron, in exchange to this Data Precision 8200.Nice trade. i always wondered how those newer Wellers are.I've the same setup with an additional iron (WMP) and WDH20T stand (connects to the WD1 to fully utilize the setback features; works with both irons).
Performance on both irons is excellent IME (good thermal recovery). For example, I can solder at 500F without being on the joint too long (assuming I'm not soldering over a ground plane).
And as you're in the US, you should give the Hakko FX-951 serious consideration (it uses cartridge tips, but they're not expensive; ~$11 for common profiles/shapes). Simply put, it's an amazing value as well as an excellent performer. Another benefit is the thickness of the plating on Hakko's tips is such that tips will last for a decade with simple care (keep it clean & tinned).
Between the two, I'd go for the Hakko. Unfortunately, it wasn't out yet when I bought what I'm currently using.
Another brand to consider would be Ersa if you're after a really good station that doesn't use cartridge tips (their tips are also very well made).
FWIW, I mention the tip thickness as Weller has had some QC issues with the LT series & ET series tips that are made in Bosnia or Mexico respectively. A quick check of the good vs. bad tips I've gotten, it's ~33% (i.e. the plating sloughs off or is cracked). Their tips made in the US, Germany, or Japan don't have these issues.
The perfect car for a Learner driver (my daughter), all brakes, safety cage and minimal horsepower, getting retro-cool (almost).
20161214 edit to add 2nd pic - a few more bits and pieces recently, for a future larger 3D printer (sort of) project.Who's your screw dealer? Every time I've looked, I either can't find what I want, or the price is a bit of a piss take.
