Smd soldering practice kit and some cheap tweezers.
I have those exact same tweezers and I think they are pretty good. I am sure more expensive ones are nicer, but those have never sent a component flying across the room.
I was just about to write the same reply.
That is good news. Think I only paid postage on it.
Was ordered on the the 5th of Feb and only received it now.
Sent from my SM-N950F using Tapatalk
I have a couple of them also. Nice value for the money.
Another TI-68 for my little collection
This is the first model with the metal bezel and screws. The LCD had issues but after giving the flex connector some love (and 150°C), it looks like fresh from the factory.
Paid 10,50€ for it and couldn't be any happier.
150C, yikes, what did you do to the poor thing then?
I have one of those as well, I seem to collect scientific calculators.
I wouldn't call myself a collector. I just tend to fall in love with some calculators with alphanumeric display for some reason. Also bought an HP 42S recently but the display has very bad contrast.
Anyway, the TI-68 is notorious for having issues with the flex connector and going over the PCB connection with a soldering iron at ~150°C tends to cure it without melting the connector.
Worked for this one for sure. The display was barely readable with several columns and rows missing before:
Thats a neat trick, I've got a couple Texas Ti58's, A Silver Ti (can't remember the model number) in a clam shell case, a black Ti68, Ti86 and also a Ti92 but my daily calc is a Commodore SR4912 with red led display, neat.
Cypress FX2/LP mini eval board (link is to Sigrok wiki page). For USB high speed transfer experiments: perhaps I could cobble together a 1 Msps 8-16 bit ADC with a differential front-end for measuring unipolar signals up to 12 volts (15 volts) or so. Would be quite useful for measuring supply glitches on SBCs, as I lack proper test equipment. The ADC would use the measurement ground, isolated from the FX2 using e.g. Si86xx digital isolators, so technically the ADC does not even need to have differential inputs. The FX2 itself uses USB host power and ground. Power for the ADC and its analog front end (voltage divider and buffer opamp, or an inamp with sub-unity gain) would be from a battery, to avoid the noise from an isolated DC-DC converter.
I had that exact model in high school and college, in fact I still have it in a drawer in my study, fantastic calculator!
Yeah, well, it has some weird limitations like supporting binary only to +/-511, limiting variable names to three characters (or so) and not being fully programmable (loops etc.), but it has pretty good support for complex numbers and it sure has style.
"Trying is the first step towards failure." - Homer J. Simpson
"If everything you try works, you aren't trying hard enough." - Gordon Moore
Considering it's ~1992 vintage is pretty decent imo.
I think I might have one of those TI-68 calculators. Seems like the display was badly discolored, but I haven't seen it in years. Stored away in a box somewhere probably. I know I have a TI-83 and a TI-30, so they're probably all in the same box. I may have to dig them out to take a look.
I think I've got a heavily worn TI-55 III somewhere too, that was my 1st TI calc - I traded an Armatron for it in High School.
Again, missing or weak columns/rows of the TI-68's display are usually caused by the flex connector and can be cured with a soldering iron at ~150°C.
The display actually has a quite good contrast .. specifically for a matrix display of that period. The displays of e.g. the HP 42S and the TI 85 are barely readable in low light situations and/or under certain angles no matter what contrast setting you use and so you find yourself tweaking the settings all the time.
My Plastic ran into the slightly infamous alice110.... on evilbay for the first time. Wonders should I start being a shill for $$ too
All jokes aside nice range of 'stuff'.
Also took delivery of some Neons after a little bigclive inspiration. Bending jig for flowers made suits 3-6mm Neons or Leds and ran up a few samples.
Hi
Recently just got this
Was spares or repair. Sadly completely dead
I snared this today on the evilbay for a good price, now I'm even better placed to calibrate my own meters
Repaired the hot-bar connected flat-flex. Dave does the same thing in this repair:
My screen is still in perfect working order ... still running off batteries from College too!
I actually got this last week, but one of the digits didn't light up. It took me until yesterday to get around to fixing it. I just wanted a basic calculator to keep by the living room computer with a display I could see in subdued light.
So I should so, college was only a few months ago. 🤣🤣🤣
From mobile device so predictive text might have struck again [emoji83]
Lol, that was in the 90's for me!
Yep, that's the big problem with LCD screens, hence my main calculator has LEDS nice, red glow and easy on the eyes.
So it should be, college was only a few months ago. 🤣🤣🤣
Mine was in the late 60s hence the red LEDS, my first foray into LCDS happened years after I left college but the trusty old Commodore SR4912 is still as good as new.
I forgot to add this photo of my TI-68 to my earlier post. The digits all work fine but there's a strange brownish discoloration across the bottom of the display. Whatever it is must be in or behind the clear plastic because it won't clean off.
