Der EE is HR
Now to get an English manual somewhere !!!
Cheers,
DC1MC
Yesterday I received a 2KVA (8A) Variac.
https://www.amazon.es/Transformador-salida-variable-2000Watt-0-250V/dp/B01BAU5N2I/ref=sr_1_2?ie=UTF8&qid=1543565463&sr=8-2
It is already heavily modified as of today!
Nice!
6115A, $37USD from evilBay, mid 80s vintage. It had many of the reported issues, buzzing film cap across the transformer, bad contacts setting the voltage, very dirty PCB, oil oozing out of the clear plastic cable tubes, broken binding parts, and a bad electrolytic capacitor. Even still, it mostly worked when delivered.
My WorkBench got a much needed Component Storage upgrade today!
And accurate for DC current too That and the 121GW are in my onsite bag but if I had to slim it down further for plane travel then the UNI-T would do nicely as an all rounder.
My bike has a layer of dust on it and it's nowhere near a CNC machine.
That's just the dreary ever-descending dust of distraction and disappointment. Router dust is from the Devil, bringing death and destruction of devices.
jus got my new clamp meter
Uni-t UT210E which is more than enough for my work
I can't say enough good things about these wee meters. The are awesome! I thought the one I had got was just a lucky one as it was so accurate but it seems others who have the same meter feel the same. Enjoy!
I can't say enough good things about these wee meters. The are awesome! I thought the one I had got was just a lucky one as it was so accurate but it seems others who have the same meter feel the same. Enjoy!yup
it is great, but is there anyway to connect it to oscilloscope as current clamp ?
There is a thread of that somewhere. But I believe the bandwidth is not high enough. If you want to measure DC current on you scope, get yourself some CMS3005 units while stock lasts.
In the big thread about the UT-210E some people have modified it to allow tapping off the signal to a scope.
Received one of these strange, but dirt cheap Chinese frequency meters:
https://www.ebay.de/itm/plj-8led-h-hf-signal-frequenzzähler-zähler-tester-modul-0-1-1000mhz/392058493508
Naturally without any manual AND the red/black wires for the power and anemic signal connector inverted !!!
But it turns on, the blue digits are to die for AND it even measures my scope 1KHz calibration taps (soon I'll even start the generator to see how far does it go, but after I'll rework the input).
Playing with the front buttons I've got selection from:
Channel A/B ?!?!?
Digital filter On/Off
A number to set:
IF xxxxxxxx
Pressing and holding both at power up, displays the firmware version: 2015.11.something
If somebody has already a manual for it, I will appreciate it.
Cheers,
DC1MC
Channel A/B ?!?!?
A number to set:
IF xxxxxxxx
Cheers,
DC1MC
Channel A/B ?!?!?
A number to set:
IF xxxxxxxx
Cheers,
DC1MC
Channel A/B ?!?!?
A number to set:
IF xxxxxxxx
Cheers,
DC1MC
