I’m pretty sure low cost devices still have a profit margin of magnitude of 4 to 5 the production cost.
Yes, but that's not what an oscilloscope like this is. Low cost might be true of some Fnirsi garbage, but not a scope like this.
Im not talking about that garbage, but devices selling for 5k often cost less than 1k all included.
That doesn't make any sense. As it stands, there's nothing in the price range that competes with the Magnova's feature set. It will be even better after the next firmware update.
Essentially, all modern digital scopes work roughly the same way, but Magnova should lose points for the same behavior seen on scopes from brands/models that cost significantly more?
For a private person, the amount is not at all easy affordable for a single hobby device.
How many amateurs really need 0.5% gain accuracy, more than 60dB channel-to channel isolation, very-very low noise for the input stage, 80 dB spurious-free dynamic range and so on.
Seriously?
So far, Magnova is very close to MicSig (I know what I am talking about; I have one MicSig in my lab), except for the price.
If we are talking about ''premium segment'' - Magnova isn't? 350 MHz bandwidth for 5K EUR? It's NOT a premium segment?
''German quality'' is not a statement? No?![]()
Magnova pretends to be the scope of the premium segment. Unfortunately, guys who develop it are complete greenies in this niche.
p.s. one more thing that is NOT acceptable to me. Again, maybe I am different. Maybe I am from another planet, but taking into account my experience, I was 100% confident that the basics in Magnova were covered correctly (by basics, I mean all these issues with aliasing/interference, hires mode, etc.). Ok, shit happens. But the thing that is not acceptable - Andre and the dev team lost their ability to comment/answer their uncomfortable topics.
As a private person I have an RTB2004 with all icense. I need it to feel lucky, even if the hardware is a little bit dodgy. On my desktop in the company I have a much smaller HMO2024, so I feel sad every day at work now.
We are not living in the 70th where an ingeneer can play in the company with the good toys. Now company work is 90% writing bullshit paper. If you wish to be a good experienced and skilled engineer you need the big toy at home.
Olaf
...which is normally completely unusual in normal use...
Oh, it's sad to say this. You basically solve various problems at work with your own equipment.
And here we are. Magnova is the new class of the product. A "luxury" scope. It has competent performance, scope parameters considered. But 350 MHz version cost hovers in 500 Mhz-1 GHz BW scopes. That is a hard limit that you
And here we are. Magnova is the new class of the product. A "luxury" scope. It has competent performance, scope parameters considered. But 350 MHz version cost hovers in 500 Mhz-1 GHz BW scopes. That is a hard limit that you cannot "luxure around" etc etc...
For Magnova they can build in whatever they can do, because software is more or less for free. (eye pattern from R&S? ten grands?) Of course if you need the fastes ADC/Asic you will go to the expensive brand, but a company like Batronix will give you more bells&whistles for the everyday scope.
Other things for me that are not luxuries, but requirements:
large screen
excellent update rate
proper shading on channels
excellent & reliable encoders
external reference input
Thanks,
Josh
And I personally would rather get SDS3104xHD for a bit more money than Magnova. Scope wise it is more powerful scope in several aspects. From BW to math, analysis functions etc.
Although oscilloscope manufacturers could better explain the importance of these things in literature/videos sometimes, especially for users who think they are into analog rather than fast digital edges, users should also take self responsibility for educating themselves.
Modern scopes have great processing capability that allow new analyses, and computations and presentations to be done differently, revealing deeper signal behaviour provided the user is willing to learn how to make use of the capabilities. Audio amplifier and power supply designs can easily misbehave in the hundreds of MHz. Many people still do not realise they may benefit from modern hardware/software performance and features, GigSample/sec rates and higher BW.
The metal case can be impractical. Unless one has total faith in the anodizing, the logic probe case possibly needs wrapping in sticky tape before going near large PCBs.
screen = ok, agree. But, if necessary, an external display can be connected (actual for MXO3, for example)
update rate = nothing special in 2026
encoders = agree, but knobs, for example, are... nothing special (cheap plastics).
Btw, here is one more innovation (sure, not bug or disadvantage).
Input: 10MHz, sine wave.
Yes, I understand why this happened, but again, a clear indication of ADC overload should be added. Ups, this will work only with conjunction with ''burst'' packs for low samplerate settings...
On the other hand, for low sample rate settings, why isn't Hi-Res added automatically?
Or, all this is done for never-ending touchscreen performance testing? One more extra feature?
Present your case, and there's a chance you may see some of those features added.
). I wouldn't want it turned off automatically either. Every user's needs/workflow is different, and anything that automatically changes a test setup that dramatically without user control is a potential issue.computations and presentations from incorrectly captured signal
But I am more than happy to see here a lot of well-educated people, real specialists in modern scopes
Thanks for the aliasing videos; that was something new for me.
screen = ok, agree. But, if necessary, an external display can be connected (actual for MXO3, for example)True, depending on the scope. But I don't want to rely on an external screen. I also have a 32" screen externally connected to the Magnova.Quoteupdate rate = nothing special in 2026That's (unfortunately) not true. We've compared this with other scopes, and there's little that compares even close to, or above this price point. Please share an example of other scopes with higher update rates.Quoteencoders = agree, but knobs, for example, are... nothing special (cheap plastics).lol so what? The knobs feel nice, and you wouldn't want them to weigh 10 pounds and be tedious to turn. Light plastic knobs are easier to manipulate and isolated from the metal electronics. Those are both good things. I don't know what they cost, but as a guy that builds a lot of products with a variety of knobs, I don't think they're cheap. I don't care if they cost them 1 penny, they feel fine. I just don't think that's the case. In any case, the quality of the encoders is paramount.QuoteBtw, here is one more innovation (sure, not bug or disadvantage).
Or, all this is done for never-ending touchscreen performance testing? One more extra feature?Now you're making feature requests. Nothing wrong with that!Present your case, and there's a chance you may see some of those features added.
Personally though, I don't want things like Hi-Res automatically added. I need to be in control of my test setup, otherwise the setup may not be valid for comparison if I didn't note that something like Hi-Res was automatically turned on (it's bad enough when I forget something I did). I wouldn't want it turned off automatically either. Every user's needs/workflow is different, and anything that automatically changes a test setup that dramatically without user control is a potential issue.
Thanks,
Josh
I agree with most of what you say, however, bandwidth isn't everything. Bandwidth is only really a cost factor when comparing the same scope line with different bandwidth models. Bandwidth also only comes in to play depending on a user's bw needs.
large screen
My choice for scope after the SDS2000X HD was the Magnova vs. the SDS3000X HD. In every aspect of my requirements, the Magnova wins.
I need a bigger screen with better quality. It's not optional. My eyes are a pain in the butt sometimes, and I've had no issues with the Magnova.
The update rate and channel shading / grading is no competition either. The SDS3000X HD pales in comparison. Even the SDS5000X HD series is worse in this regard. The shading/grading issue Siglent can fix, but they don't seem to think it's a priority.
I like good encoders. I like to use them in my workflow, and I appreciate them working with excellent precision consistently. This isn't a luxury, though it might feel like it compared to other TE with junk knobs and poor UI handling of those junk knobs.
Finally, I require external reference input. Is it a luxury? Maybe, but it annoys me not having it. Nothing less than the more expensive SDS5000X HD has it in the Siglent HD range.
So, as always, it comes down to user preference for what is needed for workflow. Things are only luxuries if they go beyond necessity. That might be true of the metal case, but it's also functional as a heatsink, and helps with the Magnova's excellent thermal performance. You also have to consider how many high-end scopes that were made with plastic shells became unusable because of their plastic shells deteriorating.For Magnova they can build in whatever they can do, because software is more or less for free. (eye pattern from R&S? ten grands?) Of course if you need the fastes ADC/Asic you will go to the expensive brand, but a company like Batronix will give you more bells&whistles for the everyday scope.
Software / options are free to Magnova users, but you can be sure it costs Batronix money to develop those things.
Thanks,
Josh
Because lots of people have this misunderstanding that certain level of money guarantees ALL parameters will be superb. They won't. Different devices will have money spent on different focus. Trick is to choose device that has focus where you need it and is wanting where you don't care.
Hmmm, how many scopes do you have at this point?![]()
Way too many.... I have a problem.. I know...
