From here:
http://www.pbs.org/parents/education/going-to-school/grade-by-grade/fourth/
"Fourth graders read, write, compare, add, subtract, multiply, and divide with very large whole numbers. They do more equations with fractions and decimals...". See the attached screenshot.
One of my few big complaints about the scope.
Looks like there is a new video (or at least YouTube just recommended it to me). Unfortunately in Portuguese again:
https://youtu.be/ZNDdfAcP2xc
He basically explains that the more acquistion memory the better and why, using a CAN decoding example.
Just had a look at history/segmented mode :
At $6k it is still $4k more expensive compared to the GW Instek MSO2000AE which has a similar feature set (some pros & cons compared to RTB2000). I'm not sure if a bigger screen, 10bit ADCs and deeper segmented memory are worth $4k though.
People have been saying "$8k scope" a lot and that's not really true because if someone were to buy the fully loaded package they wouldn't pay for options individually, they'd get the all the decodes / wavegen / segmented memory in the option pack instead ($1260). So the full retail price is actually US$6025 without any discounts.
It's going to take a long time to really feel comfortable with all of the features in this scope, but I already like it better than my Siglent SDS2304X because of the touchscreen and better button/knob layout.
*Brian
Just had a look at history/segmented mode : ....Some Keysight scopes can be made to do circular buffering (like a history mode) if you enable the circular segmented recording option (which isn't official). Other than that the way segmented recording and selecting memory lengths are implemented in the RTB2000 is quite standard compared to other DSOs (except Keysight).
Just had a look at history/segmented mode : ....Some Keysight scopes can be made to do circular buffering (like a history mode) if you enable the circular segmented recording option (which isn't official). Other than that the way segmented recording and selecting memory lengths are implemented in the RTB2000 is quite standard compared to other DSOs (except Keysight).Can you tell how to get the circular segmented recording option without changing option-id-resistors or being sued/shot by Keysight?
Cause its a very nice feature to have a permanent history available. In many cases you´ll may see a glitch or infrequent event ..
I also received mine today, and have played with it for about 10 minutes. First impressions:
*Brian
Has anyone been able to try the data (waveform data) capture functionality yet?
I'm mainly interested in how fast the transfer is over e.g. the LAN interface.
Not knowing much about it, do you have a way to test this out that I could try for you? I have the scope's webpage up (which is really, really nice and very, very fast) but I don't see anything about transferring waveform data on the webpage anywhere.
