We do not compensate for any damage using this product.
It may short-circuit and damage the equipment that uses the battery.
(Edit) Just spotted this damning admission further down:QuoteIt may short-circuit and damage the equipment that uses the battery.
W T actual F ...
Dave
Latest gadget created in America.
Batteroo (Batterizer) is a ultra low-profile sleeve shaped device installed on battery.
It can be inserted into the battery case of many machinery and tools using batteries.
There exists battery capacity not able to used sufficiently due to descent of voltage in second half of battery use.
Batteroo is the device in order to exhaust to the end the battery after the voltage descent and could only throw away until now.
When the voltage of the dry cell is regulated in the above case, it output the same electric current and when the voltage descends, a voltage up circuit maintains the prescribed voltage and shows battery performance until the last of the life.
Depending on the implement use, battery can maintain performance up to 3 ~ 6 times.
Please agree to the following instructions at the time of the purchase.
1. This product cannot be returned. After the purchase, it cannot be returned even if the size is not correct. It can attach to most battery and insert into many battery box, but not guarantee to support all battery and battery box.
2. The life span extension result of all battery and all devices using battery cannot be guaranteed. There may be case that the battery cannot show efficacy due to special characteristic of the device.
3. Please do not insert forcibly into battery box. The device and battery box may be damaged.
4. I do not compensate for any kind of damage in using this product. There is no compensation without exception concerning damage to battery operated device.
5. When the size is not correct, please cancel use. Please confirm that there is not damage at the time of the arrival of the product.
6. Please do not use devices such as tweezers for insertion into battery box. There is possibility to cause short and damage battery operated device.
7. Exclusively for disposable batteries. When used for rechargeable batteries, it may reduce number of charge times and decrease battery life due to over discharge.
If the sleeve can short out a cell in your $1000 device, that could be very nasty. If you can show that the device is inherently unreliable, that is very hard for Batteroo to counter. I just think it is worth someone spending a few hours on this.
It's never "a few hours"
This Contest is also not open to employees or independent contractors, or immediate family members (spouses, domestic partners, parents, grandparents, siblings, children, and grandchildren) or those living in the same household of employees or independent contractors of any entity involved in any aspect of the Contest (including funding, judging or administration), and each of their respective parents, subsidiaries, affiliates, advisors, or advertising/promotion agencies.
Farid has entered the Batteroo video competition...
https://www.youtube.com/playlist?list=PLX2PNUk4NKGKoEAJjsqlp1pAX1gj7Efoj
So fiddly it needs a "best practices" guide!
https://www.batteroo.com/blog/batteroo-boost-best-practices.html
HEADLINE
I'm pretty sure they've even managed to get the "Lorem ipsum" wrong...
Well they did buy an award for Best Practices in the Field of Innovation Management Strategic Engineering Stakeholder Development or somesuch bollocks...
I left them a comment... I wonder how long before they block me from the channel & delete my comment..
The Batteroo YouTube view counts are still increasing rapidly. What's also interesting are the clusters of moronic positive comments that have suddenly appeared and all at the same time (7 hours ago).
It is only visible to you, they changed the settings for comments to "approved". That's tricky if you don't know it, like shadow-banning.
Wow.. indeed shadow-banning.. So I guess my comment will never see the light
That should also mean they need to manually approve possibly hundreds of fake comments..
http://www.onenotsoboredmommy.com/2017/02/batteroo-extend-your-battery-life-for.html
