1) Can I update to the last FW without having the last bootloader ?
2) What is the last stable FW for the scope ?
2a) Is the last FW hackable ?
1) Can I update to the last FW without having the last bootloader ?Yes.2) What is the last stable FW for the scope ?
2a) Is the last FW hackable ?04.04.01.01
Yes.
The last firmware has apparently a bug on SOME devices, which seems to be linked to some older boot loader version. This has caused Rigol to withdraw the last firmware from its download site and it is expected that a corrected firmware will be published in January 2017.
- People who already had flashed that last firmware and experienced no problem are fine.
- People who got a new device delivered with that last firmware are fine.
- People who flashed the firmware and had problems (apparently 1 person so far), sent the device in for repair/downgrade.
So:
Do you have the last firmware? Yes: Great! No: Then do not upgrade it with the problematic firmware. Wait for the new release and only use firmware from Rigol's website.
You like living on the razor's edge? Get the last firmware and flash it. Chances are, it will just work.
I never read about a "reboot after so many hours" problem, though.
All I have written here, has been posted in the Rigol DS1054Z related threads.
Regards,
Vitor
So I've understood that the mine version (SP2) correspond to the latest official version of the FW of the scope.
I've tried to install all the option but with the 5mV/div the signal level goes down out of the screen, also after the calibration. So , with telnet, I've removed all the option and reinstalled with the option DSER (all but without the 5mV/div).
Yes, that option doesn't work.
It is possible to roll back to an older version ?
I've checked my scope the FW is the following:
Model:DS1104Z
SN:DS1ZA181xxxxxx
Manufacturer:RIGOL TECHNOLOGIES
Board Ver:0.1.1
Firmware Ver:0.2.3.11
BOOT Ver:0.0.1.4
CPLD Ver:1.1
SoftWare Ver:00.04.03.SP2
Model:DS1104Z
SN:DS1ZA181xxxxxx
Board Ver:0.1.1
BOOT Ver:0.0.1.4
CPLD Ver:1.1
SoftWare Ver:00.04.03.SP2Were do you find this info? Utility -> System -> System Info is what I do, but I do not get Firmware version, Boot version or CPLD version. I also tried the *IDN? SCPI command and get the same info except Board Version is not present.
Strangely not.
Model:DS1104Z
SN:DS1ZA181xxxxxx
Board Ver:0.1.1
BOOT Ver:0.0.1.4
CPLD Ver:1.1
So:
Regards,
Vitor
I have just ordered a DS1054. I assume it will be on FW: 04.03.02.03. I would like to "hack" my unit and get the upgraded features. Once I apply the hack will it still be possible to update to the new firmware when it is released later this month?
My question is: Is it possible to let the scope calculate the VRMS, Vp-p and frequency on the "math curve", like it can on the four independent channels?
I'm unable to access the "network settings" portion of the web interface on a ds1054z (04.04.SP1) The page prompts for credentials but the defaults (empty username, "111111" as password) don't work.
Interestingly enough it is possible to successfully change the password in a different part of the web interface (no username is required to do this) using "111111" as the old password. So the default password does seem to be valid. Any thoughts on this?
I mailed this question to Rigol support for my scope and received next answer:
Could you try this user name / password with your device, please?
username: test
password.: 111111
Please note: password / user name doesn't work on some units.
If you have the same behavior this will be reworked with next firmware update (planned end of January 2017).
I hope this helps.
Hi!
I have a question about the math functionality. A few days ago I was probing the output of a 24v class D amplifier, where both the plus and the minus output is driven for maximal amplitude. To accomplish the "rectified signal" has a DC component referenced to ground, so if I'm going to measure the speaker output, I'll have to do a differential measurement.
The math operation suitable for this is the A-B operation, and the result is displayed as a purple wave at the screen. My question is: Is it possible to let the scope calculate the VRMS, Vp-p and frequency on the "math curve", like it can on the four independent channels? At the moment I've been using the cursors, but it would be much better if it could do it automatically!
You can read the password with this SCPI command:
:LAN:PASSword?
For the user name I know of no SCPI command.
Peter
