This this, it's rather been a walk in the park, it's working and the resistor didn't let the smoke out. It's a high overload type used for electrical braking in servo drives.
I do see an error however.
Yeah I've got the high voltage generation sorted. That's not an issue. I'm using a flyback converter for that with a voltage comparator to set the max voltage. The problem I have is sweeping the voltage up and down at around 50Hz across the full compliance range. I think I have a solution. The phase shift is coming from the excessive miller capacitance of the pass transistor.
Anyway today's task is writing a Gopher client in Go. Why? Why the fuck not. Mostly working already!
Nice tidy example tggzzz !
Brings a tear to the eye of a previous D83 owner.
I've added another couple of goodies: manuals (now scanned and uploaded to ko4bb) and extender card
I've got a DM63 as well, in the storage cupboard. It certainly is heavy. Last time I turned it on, it worked in variable persistence mode OK but true storage was long gone. I wonder if it still works?
The curtains are BROWN.
Or in quaint British.......a trolley.
So I was going to pull out the Type 310A and work it some more but decided instead to tear down bench 1 and finish the painting. Here it is with the upper shelving pulled down. Took me all morning to complete it. I still have to pull out the bench itself so I can clean behind it, put up the edging tape, and then the actual painting. That will be tomorrow. Stay tuned.
Or in quaint British.......a trolley.A trolley carries Tea, or cakes, or similar comestibles. A cart has a horse in front of it. A barrow is the human powered equivalent of a cart, so I think that's a barrow; which would make you a Barrow boy.
Should I send you a box of dye ? Otoh Dupont is not too far from you, it should be no problem to obtain the roper chemical for morphing your curtains ...
"Luverly scopes, get yours 'ere!"
" 'Ere missus, wouldn't yer old man love to sit down to a nice dual channel plug in tonight? Cheap at 'alf the price! All guaranteed nicely matured! Not a duff cap amongst them! "
So what does that make this?
Thank you Captain Obvious for pointing that out.
A stereo photo of you delivering milk when you were a lad? A bit before you got the original prehistoric Rocky Horror T-shirt?
"On the Internet, nobody knows you're a dog"
Edited to add: And I'm sure that everybody here would agree that "Who's a good boy?" could be answered by "Tggzzz is. Yes he is".
Drat. Secret's out.
Ah, so you're trying to drum up work!
DRATS I'VE BEEN DISCOVERED!
Check the time stamps. Looks like today is my day for outing people. (It's OK med, I'm not going to tell them about the New Yorkhankycurtain colour code.)
