A 12 - 18 GHz signal generator I got for $10 from a ham radio swap meet a couple months ago. Someone cut off and removed one of the potentiometers for some unknown reason, but it was simple enough to replace. (I had to reverse engineer the schematics just to figure out which wire went where though).
The mechanism is quite cool, the knob rotates both a cam and the readout through a series of gears. The cam controls the size of the resonant cavity, and the readout is mechanically linked to the cam. It is quite accurate (off by <50 MHz at 13GHz, an error of 0.4%). The output power (not counting cable loss which is probably significant at these frequencies) drops off significantly at higher frequencies, but it is above 10dBm at the lower range.
You can see the isolator, PIN modulator, and filter on the side. The PIN modulator allows for AM modulation.
Those are quite nice little oscillators. Typically original use was sources on RF test set-ups with slotted lines etc.
Note the ganged potentiometer on the end of the camshaft. This adjusts the oscillator bias across the frequency range. One thing they are good for in a modern lab is a low phase noise source. As long as the capacitors are OK and there is no mechanical vibration around :-)
Robert.
HP 86290A that I bought for $15.
I didn't have the 8620C (which is where the module plugs into), so I ended up hooking it up to two power supplies to get all the voltage rails necessary to power it. A process meter was used to set the tune voltage.
There was nothing wrong with it apart from a leaky capacitor and some broken lamps (in the front).
There is a 30dB attenuator which is why the spectrum analyzer output looks very low.
I will try to design my own PLL microwave synthesizer using this module (so the 8620C isn't really useful anyways). I will also need to design my own power supply on a PCB.
I did rescue (buy) two 8620C from the forum scrapper, one of which has the scales for that 86290C.
Maybe I can salvage one that would fit, from my hollow state Tek scopes.
2) Entered the service menu and wrote down all the cal constants, 100 memory locations. I also filmed a video clip as Tggzzz suggested, not a bad idea.
5) PSU : no need to worry about the RIFA : I pulled the PSU and turns out they had ALREADY exploded before I bought the scope ! One of them even took out some component, impossible to identify any longer if it was not for the service manual : apparently it's (was....) a 68 ohm resistor, mounted in series with the RIFA.
Tggzzz if you could post or e-mail me your 3D model, I could try to do like you did and order it from this company.... well first check how much they would charge in shipping, then add customs and all that crap. It's gonna be an expensive collet...
BTW how do you handle the metal insert of the collet ? Do you strip it of the plastic remains, then pput a drop of super glue on it the press fit your 3D collet onto it ?
In the meantime I guess I can just try to super glue it back together, might last long enough to let me fix the electrical fault in the fan control circuitry.
I really was not planning on restoring a scope right now, really not, am doing other things. So I will try to expedite these jobs ASAP and move on... if just because the scope is not safe to use, for fear of overheating the precious many ASIC's in there. So the sooner I get all that done, the sooner I can actually use that scope. Isn't it.
0x100, of course
Yup.
Look at the prepreg under the resistor. One of mine has a 1cm diameter hole in the prepreg.
YMMV.I used ROX05S 0.5W flameproof resistors for replacements (ROX05 would probably have been better, those are slightly larger size, similar to the originals), I disagree with the 2465B thread, these are safety critical parts IMO, I can only imagine the damage with 2W resistors if the the cap in series shorts, or thermistor in parallel goes openYMMV.
Thanks wil have a look... huuuu, wow, 72 PAGES ?!
I will ask ChatGPB to make me a one page synthesis of the thread with thumbnails I can click to go direct to the most interesting/relevant posts.
I tend to agree.
Question for when you've been at the pub for a few hours: is it better to have a small resistor that spontaneously dissassembles itself, or a larger resistor that remains composed but becomes visibly enraged?
I tend to agree.
What about fusible resistors? Just spitballing....
Solartron 7081 part 2, removing Schaffner madness...
I'm not impressed with whoever serviced it last, they did manage to replace the leaked NiCd with a NiMh, but left some corrosion behind. Also one of the board connectors was part way out of the socket. TER void seals from approx 15 years ago were intact before I started.
After replacing the filter block, I was surprized to see it display "resumed" when powered up, this means the NiMh held some charge. It was then left for a few hours with a 10x 100k resistor box attached, spec is supposed to be 0.01%, it's reading a bit low with the 7081 & a HP 34401A.
" measurements take twice as long, so only 100 are necessary.I did take more readings of the resistor box & Time millivolt source last weekend with a HP 34401A, but sods law the page of notes has since vanished.
Next will be finding a RS232 lead and seeing if any of my old laptops will communicate with the 7081. In the 7081 brochure a Commodore PET is shown in one picture, something like this one.
Getting somewhere with Kicad and the TE related Panaplex footprints (need to double check the NPTH size), going to build a test board.Very good ! Thanks, now I fdo'nt have to mess around doing the same thing, you can just send me your Kicad file !
.. and I will just add a DIL footprint to it, wire up the traces and call it a day...That's one messed up footprint those things have....One must wonder what kind of a pre patent application pin arrangement study group was formed.
Very messed up datasheets too, it seems.
Datasheet I used last week;
http://www.tube-tester.com/sites/nixie/dat_arch/Sperry_01.pdf
Found another datasheet;
https://www.waynekirkwood.com/images/pdf/Sperry_Information_Displays_Catalog_1973.pdf
Oddly this datasheet gives 0.025-0.028 hole diameter for the pins, the one I used before gives 0.028-0.031.
And fill tube dimensions are different on both datasheets, need to check which matches the devices I have, it's not the only difference in the two datasheet, display height & fill tube dimensions are also different.![]()
Seems the large hole is not centred on the fill tube, in the Anadex counter, possibly due to datasheet error.
Will have to finish the Kicad footprint sometime next week, hopefully I can add it here.
Close up of the slightly faulty NOS display, seems to have uneven/missing plating on the bottom segment.
Used working one in the Anadex counter for comparison.
P.S. Friday evening was a bit of a disaster, had about 1/2" deep of water, in the workshop after heavy rain. It took several hours to clear the water, with a dumpster dived mini wet vacuum cleaner (part of carpet washer) and a mop for the rest, Saturday the roof drain was cleared of accumulated sandy mud. No TE casualties thankfully, as I know not to leave them directly on the floor, have been using wood blocks for years to prevent corrosion issues.
