Here's first pass schematic for a precision 190mv, 1.9V, and 19V reference. I decided to go with a design so each voltage could be very precisely set individually for maximum accuracy. It's a higher parts count but not really all that more complex. Now to generate a parts list and get an order in.
Feel free to provide input/suggestions.
Edit.....I'm going to put a design thought for a 500VDC reference on paper too. Watch this space.
DANGER!!!
50,000 OHMS!!!
*Unbalanced input*
Martin, that's a cool looking DMM but that side selector switch is really funky.![]()
washing is done, it looks much better now. Found that for 10,-€
Still won't lock.
Does it output position data on the serial port?
My location is a bit bad for receiving GPS signals:
My apartment is at street level and the GPS antennas are on the window sill of a window that's looking out to the west and onto the street where on the other side (~25m distance) there's an apartment building with 4 floors.
My apartment doesn't have windows to the south or to the north.
That is far from ideal, maybe you should try to find a way to bring an antenna outside and up, but that could be hard depending on landlord and regulations…
Not feeling brave enough to fully series-stack the inverters and run 'em both off a single 36V supply, eh?
*Star Wars time*
500 V with even a little current behind it is bound to hurt.
Needs a bit more complexity on the trim pots whose temp co's are generally horrid. Consider using lower value pots and additional low temp co fixed resistors to get it in the ballpark.
*Star Wars time*
You can't. The -V in and -V out are common. As soon as I tied -V out of one to +V in of the other....KABOOM
Still won't lock.
KISSNeeds a bit more complexity on the trim pots whose temp co's are generally horrid. Consider using lower value pots and additional low temp co fixed resistors to get it in the ballpark.
How are you going to solder them in close proximity to that thermoplastic? Seems highly unlikely you won't uglify the hell right out of it.
