Still, my scope probes have very thin and flexible cable, like the transparent stuff but black... so I guess this means it must be yet another RG-XYZ norm again ? Which one ?
Vince
A useful Coax chart I posted is in this thread:
https://www.eevblog.com/forum/testgear/quality-test-cable-rg58-alternative/
BTW, forget about using the thin flexible probe cables, they are not 50 Ohm rated and are lossy to help manage reflections.
Happy New Year, or almost new year, to everyone (depending on location)!
Hope you're doing well, or as well as can be under the circumstances. It's been a rough year. Lost some friends and family, and work has been too busy, but I hope 2022 will be better.
What are your goals, TEA or otherwise, for 2022? Mine are to acquire less TE, shrink my repair queue, and spend more time in the forum.
(And catch more typos before submitting a post.)
Happy New Year. Sorry about your losses, but hope you will be in the TEA more often.
I'm currently working on a Boonton Model 42A power meter given to me. It works but needs some TLC and it's missing a button that I'm designing at the moment. I was just now inspecting one of the boards and it looks like green corrosion on the chopper wires, so I'll be redoing those connections now.
Gald to see you back here!
Later I got one of these Advance RF signal generators from the same source that also had the dreaded Belling-Lee coax sockets, but as these were pretty common at the time, I was able to source new replacements to replace the clapped ones on the generator, from the same shop that sold me the generator.
For now I am tying to order some BNC - BNC test leads but can't make sense of the subtleties between the various acronyms/norms used to describe them. I am wondering if these norms somehow have a relation ship to the physical presentation of the cable. That is, I don't want the very thick/big diameter black one, I prefer the thin black ones. Looking at Farnell's offering, pictures and pictures of lots of their cables, I am starting to venture into thinking that the (vanilla) RG58 is the cheaper stuff of all, and has the very thick black form.
The RG58 U and / or C might look like the are black too, but thinner / more flexible. It seems to be about twice the price of the thicker RG58.
RG316 however clearly (pun intended) seem to the modern super thin transparent cable that we see all over the place. Price wise it seems to be 3 times the price of the thick RG58.
Is that right or does that have nothing to do anything ?!
What was the year of manufacture, do you know? I've this kind of thing before and mains cables made between 1965 and 1971 and this article relates.
https://www.voltimum.co.uk/articles/green-goo-0
I unsoldered those wires and stripped back the insulation just now and it doesn't look all that great, but it's a lot better than what I saw exposed. Anyway enough of that thing for this evening.Vince
Thanks for the link. Chart useful indeed, I have it in a safe place now...
Thread over there is... well, in just a handful of posts they managed to throw more cable types/norms than I can count, it's overwhelming. Clearly a whole can of worms in its own right... not qualified to go into that.
I do gather from the though, that important things are improved/ doubled screening for better signal integrity, losses which limit use at very high / Shahriar like frequencies (not my world...), and that having a stranded inner core is more important to achieve cable flexibility, than having a thin/small diameter cable. RG58 with stranded core apparently makes people happy for use on the bench as a test lead. So I should bed happy too I guess...
And foil shielding not good for test cables as won't last long on the bench, foil will deteriorate. Need braided shielding.
For now all I wanted was a quick answer to what is a decent general purpose affordable get me started with basic stuff... cable.
Seems RG58 'C' suffix is a good default choice, so will go with that for now.
Then later on if I get smarter and do fancy stuff that requires specific spec for thjis or that...then I will worry about what cable type is best for whatever it is that I want to achieve.
I guess the most likely scenario is if I get rich and can afford test gear to venture at several GHz, then maybe RG58 might have too much loss to be bearable. We shall see.
for now I am not into fancy RF stuff, so RG58 should do it I guess...
Well I do have a 3GHz scope, a TDC 694C, so I might want to get a cheap PLL like Factory just did, and sweep from 2 to 4GHz to see how it does, plot its bandwidth response out of curiosity, just for fun. But that's about as far as my "RF" needs are likely to go for the foreseeable future....
Holy crap, I can't believe some of what I'm reading here. It's actually getting borderline ridiculous.
This Heath OL-1 did not originally have that BNC connector. Someone in the past installed it.
Did it "ruin" the "originality" of the instrument? In strictest terms yes. Does this Smurf give one wit? Absolutely not. But believe it or not some dumb ass did suggest that perhaps I might want to remove it and patch the hole. Yea, right. Not happening.![]()
Did it actually increase the usability of the instrument? Absolutely which is why it was installed. In my mind that beats "originality" and this Smurf is not running a museum.![]()
P.S. Most museum pieces look great but don't freaking work. My stuff may have some rough edges but it all works.
Robert did a good walkthrough. I'd like to add that -- in your frequency areas, given the generator you've got and so on, RG series cable is going to be just fine. What you can find in terms of finished cable is probably not going to be very good. All caveats Robert discussed are going to apply to those cables; also, the connectors will probably be crap. Unless you pay a premium for say Rosenberger or similar.
[..] including a large stash of .195" BNCs, probably to set me for life: Amphenol straight and angled solder connectors of very high quality. I complement that with modern .195" cables from reputable manufacturers, like Berkenhoff & Drebes, SSB-Electronic, and Messi & Paoloni.
If lengths are going to be non-dramatic,
That which I've described above will suffice up to UHF without trouble,
[...} so I might want to get a cheap PLL like Factory just did [..]
Erm I don't have any cheap PLL thingies, maybe confused with AVGresponding and the cheap & faulty ADF 4351-based RF-gen he bought recently.
Later I got one of these Advance RF signal generators from the same source that also had the dreaded Belling-Lee coax sockets, but as these were pretty common at the time, I was able to source new replacements to replace the clapped ones on the generator, from the same shop that sold me the generator.I've got one of those Advance E2 generators as well. Surprisingly good frequency accuracy and stability for its age but the output attenuation is wildly inaccurate at lower output levels.
I blame the Belling-Lee output connector for the excess RF leakage at low output levels.
And let's not talk about GR connectors. What a nightmare they are.![]()
Currently waiting on parts for the Type 1A4 plug-in and the two Type 547's so this would be a perfect time to re-visit an old project. Install of the upgraded rectifier board in the 212 mini scope. I know I promised TERRA Operative that I would get this done by Christmas but I never expected to have a windfall of 5 plug-in's and 2 scopes to take up all my time.
Anyway, here's the built up board with the components installed. Those 2 additional parts are fuses for the battery packs. My packs already have fuses so these are spares.
@Zucca: (I'm a barbarian and I have fruit in my panna cotta.)
The two decade boxes are college lab surplus. Hopefully they haven’t been abused too badly by students. I put an LCR meter and walked the dial around and it’s a bit of a mixed bag. A few values are spot on but most are out, whether a bit high or a bit low.
As long is not pineapple on pizza, I can forgive you.
I suggest you run a 3 conductor cable (L1, L2, N) for both of your circuits (the bare ground is not counted). You can get greater flexibility of having both 120 V ( L1-N or share the load with L2-N) and 240V (L1-L2) available.
For my (hopefully soon) future lab, I am thinking of running a 120 V circuit from a 15A DFCI (dual arc and 5mA ground fault protection) breaker for any DUT.
Along with that would be a 240V circuit from a 15A EFCI (equipment protection: arc fault but only 10mA ground fault) for lots of lab equipment (15A L1-N plus 15A L2-N = 30A total at 120V), and the possibility of having 240V available for future use.
Note, that a 240V DFCI breaker is not available, otherwise I would have chosen that.
Note2, in the current supply chain circumstances, a DFCI is much cheaper than a GFCI (5mA ground fault protection)... at least locally in the GWN.
EDIT: forgot to mention it. A bunch of your breakers are labelled GFI (GFCI in the GWN), but those are just regular breakers. A GFCI breaker would have a white coloured test button. I assume that it means there are GFCI protected receptacles on the circuit. With a new-to-you place, it might be worth checking whether or not that is the case.
I'm curious, what is the search term needed to find those solder on PCB edge pins? We had them on stuff at work and I never found out what they were, in the 15-ish years I worked in the electronics lab.
Zucca, Zucca, you should know better than give your weakness away like that! Now, if you cross us, or if you do your home wiring wrong, or whatever you will do to incur our wrath - we might feel compelled to have a global, distributed Pizza Hawaii pigout and post visual evidence of it? (maybe aggravating it by wearing Bersaglieri hats?)
