Quote from: m kA pen plotter, maybe they are visiting north shortly.
Roland DXY 990
https://www.leboncoin.fr/informatique/1956772681.htm
He is never going to visit you, because he is not SELLING it, he is LOOKING for one !
Dang,
I didn't even consider the possibility.
Where it is said?
HP 400H
https://www.leboncoin.fr/collection/2110669646.htm
So the item is reserved to the buyer when seller get the money.
What if buyer is a no show?
TE update: 5316b has shipping label created. Investigating oscillator options. Perhaps should buy a 10-pack of those CTI oscillators..
There are also China surplus "VECTRON C4550A1", some of them even have the V-Ref output option (they sadly all look the same from outside).
Mine have arrived and were bought when they were only slightly more expensive then the CTI, which seems to have changed recently
A quick check indicates that 3 of 10 seem to posess the option. You'll have to decide for yourself if that sample size is representative enough.
This guy made nice A-Dev Graphs for them and gave some more details.
-- but, it seems that extra insulation improved things, right?
TE Update: 5316b package is with carrier. It's only going more or less across the metro area here, but freight costs were so low that diesel fuel spent picking it up would have cost more. Hope for tomorrow, but realistically Thursday.
Yes, that too is quite interesting. My Russian is a bit rusty, so the link was "mostly for pictures"-- but, it seems that extra insulation improved things, right?
Just received a 100x scope probe, NOS, reasonable money.
It's an Elditest GE 3121, 150MHz, 2kV, though I don't want to ever be within a mile of anything oscillating at that frequency and magnitude! Fabrique en Allemagne, so decent quality I should think.[/color=teal]Worthless unless you have the frequency derating chart.
As Tggzzz sad, would be cool to log the data over a longer period of time to observe the drift. Don't have the capability to automate this right now, lab is not that sophisticated just yet.. a week ago it was still completely unusable... give it more time please !
Amy data is better than none. Just leave the reference and meter on, and note the time/voltage whenever convenient.
That won't catch noise (thermal or popcorn) but it will show drift.
Worthless how? I already said I won't be going anywhere near frequencies like that at higher voltages. The highest it'll see is the inside of a smps. In any case the datasheet will be available from the manufacturer I'm sure; Germans are fastidious about such things.
... but... I am not sure the Vref will stay on for say 24 hours, with an LED lit very bright, with a small battery ?
Doesn't this thing turns itself off after a while, to save battery ??
Will try I guess but...
What prevents you from connecting a laboratory power supply instead of the battery?
), I put in a solid 10 hours hoeing out garage and shed to make garage usable space and to move machinery/shift gears from snow-removal mode to lawn-care mode. Took only enough time off to eat and pop handfuls of Ibuprofens...
); it has been powering a 3D Printer for 2 years, so it's past due. Noticed some primo Chinglish on the warranty seal...
Well fuck that.
ON THE BENCH TONIGHT: Temp PSU for 32in Cinema Display
Yeah, I kindof feel the same... my only valid assessment of comparative value is the $$$ of the thing as configured when new...
I don't think I'd be game to look at the gear I have in that light. IMO, it's only worth what its worth on today's values.
if I ever got my Kung-Fu up to snuff.
I wish you stop underrate yourself here. You've got the mind for it, I can tell.
The problem is that you're likely to be frustrated by the myriad things-that-look-they-might-work in most Linuxen. The complete lack of oversight, taste and regulation in the Linux world makes things a bit chaotic there. Like visiting a cliché oriental bazaar and trying to do a trend analysis of the carpet market. Every subsystem has at least 17 slightly varying graphic config utilities that each consume 8x the compute resources that the underlying actual daemon/whatever will, just to look cute. And none of them work. As soon as one gets into tinkering mode (and Dragons do!), the only path is text editor on config file.
You instead probably need to install something that is very simple and actually will deliver to promise, like one of the BSDen.
ON THE BENCH TONIGHT: Temp PSU for 32in Cinema DisplayHow you could resist to not dremel the Liteon PSU open?
Ops you opened it... well done!
Nive work, even with Z-tie :-)
Worthless how? I already said I won't be going anywhere near frequencies like that at higher voltages. The highest it'll see is the inside of a smps. In any case the datasheet will be available from the manufacturer I'm sure; Germans are fastidious about such things.Do download it and examine the frequency derating and you'll see what I mean. They rolloff big time at just a few MHz which of course you won't see in the std SMPS.
But good on ya for getting a 100x HV probe and playing it safe.
OEM appears to be French. Roll-off starts about 300 kHz. Down to about 300 V at 8 MHz. Manual here:
https://bkpmedia.s3.amazonaws.com/downloads/manuals/en-us/GE3121_manual.pdf
Current model @ £79 from Farnell https://uk.farnell.com/elditest/ge-3121/probe-osciloscp-2kv-150mhz-x100/dp/1532989
Note that the BNC is not insulated. The manual says: "Probe assemblies must not be used for measurements on mains circuits."
It's IEC1010 CAT I which is not for use on ciruits conneted to the mains. I've always thought this misleading because most people think "CAT" raings are for mains use.
This probe is not suitable for use on the primary circuits of mains SMPSUs
again.Marco Reps is selling some of his stuff:
https://www.ebay-kleinanzeigen.de/s-bestandsliste.html?userId=15084259
NAWTS
), and the Keithley 155... though it does make you wonder what he is collecting funds for.
Or just permanently charge the battery.
This probe is not suitable for use on the primary circuits of mains SMPSUsNice catch.
Had me look up the ones we carry and they are CAT IIagain.
http://www.pintek.com.tw/productDetail/land-ctop-2/index/pscsn/17073/psn/19272
It's just that... well... I've run out of patience for having to open the hood and twirl wrenches every few days. Same is true of my vehicles as well; which is why when I left Houston, I left Franken-Cruiser™ behind.
I think I've done enough penance for being born with The Knack.
Also do not understand the "clever design"
Quote from: TggzzzOr just permanently charge the battery.
That's assuming the device is designed to turn the auto-off feature off, when the charger is plugged in. I don't know that.
Anyway, that was to reply last nights comments.... now after a good night of sleep I have some good news :
I did decided to conduct the experiment, and turned the Vref on before going to bed. Just at midnight.
Now I just woke up. At 9h00, the Vref is STILL up and running, so no auto-off features it looks like !
It's my DMM that turned itself off...
So I have now two data points, 9 hours apart.
How much drift ? Zero.
I set it up to 2.5V because a) according to the datasheet of the AD584K that's the output that gives the best performance and b) it's the only output that allow me to use the full 5 digit resolution of the DMM, making it is easier/more likely to catch drift.
So, at power up got 2,5015 (2.5013 on the sticker).
9 hours later overnight, DMM still reads 2.5015....
