Snagged a working Tek 2445
Here...[/URL]
Nice one thanks for that. Have the can open. There was some plug damage to the base which appears to have buggered the switch. The bar is intact and no filter or RIFA explosions yet. Refurb it is.
Edit: fan motor is dead. Same one as a Tek 465 by the looks. I have one lying around so no mnem job required![]()
Well that 2445 sure looks good, are they new BNC's or has it just had a sheltered life. I do like a 4 channel scope with cursors and shit but that one has a fan as well and you hate fans? Did you see it working or did they say it was working?It's a fake 4 channels, notice that there are only 2 Volts/Div knobs.Yeah, its like my old scope, Iwatzu that 4 channels but the the 3rd and 4th only had 2 settings 500mV and 1V on the input, selected via push buttons, still better than just 2 channels though.
On to the 2445... Main board. U800 probably needs a heatsink...
Congrats on the 2445, looks really nice.On U800, my personal opinion only ... leave it as is, but unscrew the two nuts as they serve no purpose at all, and may do more harm than good. (subject to debate/argument)
-> My reasoning ... -> Older alternative one ...
Btw, do not let the scope run without the case on, as the vent holes below will blow air specifically to the U800, without it, it will heat up. Or use big fan blowing the whole A1 board if without the case.
Just realized, many of TEA regulars here, own Tek 24x5 A/B/plain, aren't we ?
The 1N829 Zener diode is temp compensated and do not need an oven. TC has been measured when the unit was produced and is compensated on the board (can be changed by soldering / unsoldering some solder bridges). The Solartron 7081 (8.5 digits) also has the ref placed on the board like that with no protection. But in the case of the 7081, there's a temperature sensor on the board used to correct the voltage reference dynamically.
Nevertheless, it’s true that the transformer is getting really hot. I always wonder if it was always like that or this is something that appeared over time ?
In term of noise, on my 7061, I had a lot more success when I readjusted the internal clock. The procedure is described briefly at the end of the maintenance manual.
I get 2.91V - 2.97V at TP402, so I should be good there. I know that the Zener current is hand adjusted to match each specific diode to set it to the 0 tempco point, and that's all well and good. What that adjustment can't help is when a temperature differential is created over the diode body or the diode's leads.
The transformer really does get quite warm. With the lid off, I'm measuring over 42°C. Then again, my 7150 gets just as hot, so it's probably quite normal.I think I'll see if I can get my thermocouple probe in through the earth screw on the back and see what the temperature looks like around the reference area once the meter is closed again and warmed up.
Have you seen this suspicious-looking solder joint of the 1N829A?It does look a little suspicious - you have eagle eyes! Looking closer, the leads appear not to have been soldered on the top of the board. My assumption is that they hand soldered the reference after the rest of the PCB had been flow soldered and probably used a heat sink on the top of the PCB while they soldered the legs on the bottom side.Certainly, given the current reasonable accuracy that the meter exhibits, I don't have any reason to believe that there is any problem with the connections to the reference diode.
Ditto also on never running a 24xx with the case off. Put a fan blowing across the bottom if you do, and as med can attest, do NOT stack this scope on top of other gear when in use. Keep it propped up on the bail with lots of free air underneath for a long and happy life.
It seems to me that while the clock reference procedure is important, grizewald has presented valid empirical evidence that applying insulation around the reference diode improves overall stability.
The only thing I'd be concerned with is his solution; while certainly a valid proof of concept, over the long term a ball of cotton that tends to absorb moisture from the air in direct contact with the diode's leads at a differing voltage potential just screams "electrolysis" at me... as well as potential for disrupting the reference voltage circuit if the cotton develops an oxidation trace as a result.
It looks a bit like it's a layer of lacquer that's peeling up.
I wonder if it can be fixed by using some artists fixative spray and gently pushing it back down with a small soft brush.
After that you'd want a coat of matte or satin lacquer on top
Thanks - that's the sort of ideas I'm after. Straight to top of list
On to the 2445.
Edit: you can't get a scope and not measure some rise time. So here's the HP 3312A's square output into the internal 50 ohm termination of the scope.
Manual quotes 20ns for this so it's looking pretty good.
Probably not a good idea. That fixative spray has very fast evaporating solvents - the whole idea is to minimize the time it has to do damage to a drawing - so it's not likely to stay sticky enough for long enough to press things into place.
...Ditto also on never running a 24xx with the case off. Put a fan blowing across the bottom if you do, and as med can attest, do NOT stack this scope on top of other gear when in use. Keep it propped up on the bail with lots of free air underneath for a long and happy life.
No, that's the 2430 that had the heat related failures due to improper stacking.....not the 2465.
Everything else I agree....LEAVE U800 ALONE. Do NOT mess with it.
Wise words mnementh.The cotton is a "let's see if it makes any difference" kind of mod. I certainly have no intention of leaving it as a permanent fix for just the reasons you mention. For the permanent fix, I was thinking of digging out some silica thread and making a nice little tea cosy for the diode.
My wife even stopped watching her detective drama on Netflix long enough to give me the "WTF is with you...?"
look; I NEVER giggle.
On to the 2445.
Don't, or at least measure the temp of the damn thing before getting your monkey wrench out. Then read TekScopes on the subject.
None of my 2465/2445B are more than warm to the touch (but I ought to test that with a fast sweep and minimum holdoff)QuoteEdit: you can't get a scope and not measure some rise time. So here's the HP 3312A's square output into the internal 50 ohm termination of the scope.
When are you going to test the 2445's risetime?
Thermal insulation to reduce thermal drift. Lock the clock to the mains frequency to reduce power line noise.
Well the scope had been powered up for nearly 5 hours now and is only warm. I’m good with that.
As for 2445 rise time, as soon as I’ve thrown something together that has a fast step. All I have handy is a Jim Williams jobby which is not quite good enough IMHO as it’s just a short pulse.
Edit: just found a whole tube of 74AC14N’s in the cupboard so that may be “this evening”
On to the 2445.
Well the scope had been powered up for nearly 5 hours now and is only warm. I’m good with that. As for 2445 rise time, as soon as I’ve thrown something together that has a fast step. All I have handy is a Jim Williams jobby which is not quite good enough IMHO as it’s just a short pulse. Edit: just found a whole tube of 74AC14N’s in the cupboard so that may be “this evening”
Welcome back to the dark side. I knew you couldn't stay away.I am NOT your father.
I’ve actually got some 74LVC14’s floating around but my eyes aren’t up to that this evening
I may build something decent based on your suggestion next week. Need a non radio project!
Just stumbled across this while looking at arcade joysticks on fleaBay: eBay auction: #132490173176 Not sure if it's valuable as HAM gear or not; just thought I'd bring it to the attention of those who are into aggravated aether.
*back to the bench*
*back to the bench*
