That 270 looks promising, a lot nicer than my 635 when it came through. I have done a basic cleanup on it; looks a lot nicer than this now but I still totes need to get after those jacks with a .22 cal brass brush and some silicone spray. Can't complain; got mine for CAD$13.55. If all I do is leave it perched it on the mantle, I've gotten my money's worth out of it.
Thanks. I haven't done anything to these meters at all other than hook them up and do some low voltage DC tests on them. They'd all benefit from a cleaning at minimum, for sure. Your 635 looks like it cleaned up nicely though. I have a 635 as well and the only thing I did was scrape out the 35 year old batteries and the crusty crud from where they leaked all over. Unfortunately, one of the AA battery contacts broke and went sailing into the garbage can along with the leaked battery it was attached to. I don't think it could've been saved though. The batteries were really far gone. I should've taken pictures of the inside of the 635 but instinct kicked in and I got the batteries out of there as fast as I could to prevent any more damage from happening but that ship had probably sailed at least a decade ago so there wasn't any need to rush on my part. Have you tried out your 635 at all though, even a couple of DC volt checks just to make sure the movement's still working?
I'm not sure I'd trust 3D printed parts for HV. ABS is a sponge and PLA is full of air pockets. What the breakdown voltage? Creepage distance etc? No idea, then I wouldn't put it between me and a kV source. The original parts look like they are Nylon.
McBryce.
WTFE.If you're handling that bit while its live, you DESERVE what you get.
EDIT: The Probulator end... yeah, I agree. I wouldn't print that; except maybe a hand-grip to go around a nylon, FR4 or glass tube which would be the actual probe.
EDIT-EDIT: Dang... woudja lookit that scary-ass HV cable with just a alligator on the end...? That's like... TURBO Suicide Cord; for when the usual AC Line Suicide cord isn't fast enough...
4: For a more "bespoke" look, you can use binding post screws/Chicago screws/sex bolts, available in brass, stainless and aluminum from Amazon or your local homeowner hell in a variety of lengths and they're cheap:
My Electronic Load is now 3 days old, lets drill holes in it :-)
https://youtu.be/UeVNQ4argDU
Warranty![]()
i allready opened it the day i took it out of its box...
Like looking down and finding a viper right where you were about to reach, or a tiger lurking in the undergrowth at the back wall on your bench...
What's amazing actually is that they're still generally so readily available.Oops, I did it again. Bought yet another scope, that is.
Yeah, the battery contacts are a perennial problem; fortunately Keystone makes one others have said works as a replacement, and DigiKey carries it for 81¢ each: https://www.digikey.ca/en/products/detail/keystone-electronics/5209/299941
The J-clips are a bit of a bastard; I was "going to look through their stuff someday" for a similar enough clip I thought could be manhandled into a replacement.
DigiKey's Battery Holders Clips & Contacts Dept is full of interesting stuffs, BTW... a great place to look when you need to pad an order for free shipping: https://www.digikey.ca/en/products/filter/battery-holders-clips-contacts/86
Yes, I've tested mine; voltage does cause deflection and the movement is smooth and no binding, however a couple of the current shunts are extra crispy hand-wound-on-phenolic-formers type and I haven't tackled them yet, nor have I found anything I think might be a reasonable ceramic substitute.
I may bug you to take some readings on yours somewhere over the winter when I'm stuck inside with nothing to do however. I have yet to find a schematic on the 635; instead of the usual multiples-of-5 scale, it has a oddball scale in multiples-of-3, which I guess was due to some variation in the demands of local electrical code.
Good hunting!
HOLY SHEEIT!!! I actually found the post where I read about IMS ( www.multimeter.com ); they have an assortment of Simpson parts, including OEM-style copper-colored phosphor-bronze battery clip sets: https://www.metersales.com/shop/category/parts-for-test-equpment-138
Warranty![]()
Sorry - but I have to tell you about my latest laugh...
Got a call on the landline from somebody with an accent that likely hailed from the subcontinent claiming to be from the technical department of Telstra, calling about my internet service.
Fascinating - since none of the internet services I have anything to do with are with Telstra...
My response - in a rather excited voice - was: "A scammer! It's been ages since I've had a scammer!" Just as the last syllable left my mouth, I heard "Beep - beep - beep - beep" signifying they had hung up.
I'm still smiling.
I have not encountered this term before, which I find suspicious. EMC/EMI is a topic I really strive to keep current in.
Citation:
'The TV was found to be emitting a single high-level impulse noise (SHINE), which causes electrical interference in other devices.'
The remainder is here:
https://www.bbc.com/news/uk-wales-54239180
As far as other news are concerned, I am feeling quite sick Seems I have lost in the preservability fight yesterday. WTF, it did not taste as bad as it feels!
Interesting. What did you land?
I have been researching somewhat ancient (60s) construction techniques for VHF circuits. I have decided to move my telemetry project over to APRS on 2m thus saving all sorts of horrid antenna shenanigans. Managed to transmit with an Si5351A, one MAV-11 stage and a 2n3866 PA kicking out 250mW so far which is fairly acceptable.
Oops, I did it again. Bought yet another scope, that is.Only one ?
Given that I am overloaded, one is too many. But it is small and can be flipped.
Given that I am overloaded, one is too many. But it is small and can be flipped.Overloaded with scopes, nah
Wondering if the dozen I bought yesterday is even enough.
In this group one can never have too much TE
Citation:
If it's related to openreach it says their PR team or road monkeys made up the term on the spot.
It took 18 months to fix. That's about right for them
Local Openreach engineer, Michael Jones, was determined to find the Aberhosan broadband smoking gun – so he decided to call on the assistance of colleagues from Openreach’s Chief Engineer team – the company’s telecoms equivalent of the ‘SAS’.
Send that video to the most disrespectful cretin papers. They'll be all over it after that woman killed someone pulling out of a base.
Citation:
According to el Reg it was longer. They took an unspecified period of time from when the issue was first reported to rip out all their cabling and start again, then another 18 months from there to recognise and diagnose that it was an EMI problem. Knowing BT that unspecified initial period was probably another 18 months. So, it's not just BT that hire monkeys, it looks like the BBC news also does now, to have swallowed the spin and publish it as only 18 months in total.
The originalBodge-itTelecomOpenretch press release is here.Local Openreach engineer, Michael Jones, was determined to find the Aberhosan broadband smoking gun – so he decided to call on the assistance of colleagues from Openreach’s Chief Engineer team – the company’s telecoms equivalent of the ‘SAS’.
Rough translation: "We finally handed the problem over to 'engineers' who can actually read and write, and seldom use crayon to do so."
I once had an Openretch 'engineer' come to fix a problem on my line who did not know what I was talking about when I described the noise I was hearing on the line as "white noise".
